I bought my Super Ram used so no instructions cam with it. Do I need a different throttle cable bracket than stock. I was test fitting it and it seems to have alot of slack on all three cables going to the TB.
Also for '90 owners, where did you mount the MAP sensor?
On my '85, I needed to get the throttle bracket off an F-Body that was slightly different than my stock bracket.. The stock one made the cables kink too much over the new planum.
i've got a lousy pic, but my sig shows the map sensor is mounted at the rear, opposite the TB. i can send you a gigantic view, but the batteries in my camera decided to suddenly take a dump, and i have to recharge another set i have for 24 hrs.
That's where I figured it went, but there are two vacuum fittings right under it that are now hard to get too.
