what is this??
Old Oct 25, 2005 | 11:35 AM
conv90's Avatar
conv90
Default what is this??
I have a strange plate holder attached to the wire that goes from the starter area to the coolant sensor in tha passenger side head.
Near the starter there is a series of wires. One of these (a wrapped one) goes upto the the colant sensor (the sensor in the passenger head). Around this wrapped wire there is a flat metal plate (abut 2" x 1") with some hole on it (the hole seems something to put a screw on it and seems taht this plate should be attached to something..).
There is NOTHING where I can put this plate ... SoI have this plate hanging itself without a solid conection with nothing.
What is this plate???
It's about 5" from the connector of the coolant sensor..
Please help me. I can see it also looking from the top of the coolant sensor thru the headers.
-Beppe-
Old Oct 25, 2005 | 12:58 PM
blue 85's Avatar
blue 85
there should be a hole in the head near the top of the block where you should be able to bolt it back to. you will be able to see it better from the bottom looking up. hope this helps
