'88: Car won't start; need help!
I went out this AM to drive the car to work. I have been driving it regularly for the last 60 days as it has been getting fixed from the accident. The only items remaining are painting the hood, and a bit of petty alignment issues. The car is a 1988 coupe, std, w/~65K miles. Previous damage was limited to fwd of the front suspension, and has pretty much all been replaced.
When I stuck the key in the ignition, all of the lights come on in the run position, but when going to start, the starter does not crank. The security light flashes as you continue to push the run position. The clutch is in. I had GM check the resistor pellet in the key. All appears to be in order, and I had GM cut another key (as I only had one). The new key works no better than the old key.
The GM guy said the next step would be to replace the actual ignition lock. The replacement lock is supplied with a keyed blank (no resistor pellet), and keys are purchased and cut to match the keyed blank. Cost of the ignition module is ~$65, with each key costing ~$35. This means that the new key is juat a waste (I hate throwing away money).
Should the security light blink when cranking? I thought it chould not flash, but I checked on my '87, and it flashes when the starter is cranked. Does this sound like a resistor reader issue in the ignition lock? What about the actual VATS module? Clutch safety switch issue? Is there a quick way to ensure that the starter solenoid is not an issue?
Any help would be appreciated.
Aaron
It was $49 with shipping.
I read your solution over in the other section and very much appreciated your reply. Your information was both informative and helpful. I have my problem narrowed down to the clutch switch.
There is a receipt in the car that indicated the clutch was replaced about 4 months prior to the accident. The clutch is almost all the way on the floor (very different from my other cars where the clutch release is somewhere from 40-50% depressed). I had noticed that I had to push really hard to get the car to crank at times. Would this be a misadjustment of the clutch switch? Are there slotted mounting holes? Do I bend the wire between the pedal and the clutch switch? I also think that I may need to bleed the clutch set-up to get the pedal up to decent height, before I damge the shift forks or synchros.
I was able to get the car to crank by jumpering the connector, but do not wish to put it back together this way.
On a positive note, the 2nd key was not a waste of $34. Woohoo!
Thanks for all of the help,
Aaron
One thing you might check is the bushing on the pin on the clutch pedal, it might be split, mine was. This bushing goes on the pin that the clutch rod and the clevis on the end of the rod goes over. A split bushing causes the clutch rod to move off at an angle, increasing the clutch pedal effort and increasing the stroke to disengage.
