Can a bad knock sensor cause poor emissions?
Old Oct 27, 2005 | 11:13 PM
Stngray's Avatar
Stngray
Default Can a bad knock sensor cause poor emissions?
Replaced the starter on my 86 today, and in the process destroyed the sensor in front of it. (Don't ask) Is this the knock sensor? I thought I would give it a shot and ran it through emissions, and it failed HC, Nox, and CO. On the way home, being a little upset, I got into it and noticed the knock. That was when I realized I screwed up the knock sensor (I had guessed it was the oil temp sensor ) The entire emissions system in this car was replaced two years ago, and it passed fine. If it's not the knock sensor is there any specific component I can look at that would cause the above symptoms? I am trying to get this car ready to sell, and would like to minimize my outlay.
Old Oct 28, 2005 | 12:24 AM
Trizney's Avatar
Trizney
A bad knock sensor will screw up your timing, which I can see it messing up your emissions. I would go on to say it could make your car run rich if it is pulling timing and keeping the same amount of fuel coming in. Get that replaced
Old Oct 28, 2005 | 12:57 AM
Stngray's Avatar
Stngray
Just ran up and bought a new knock sensor, pcv valve, and fuel filter. Hopefully this will fix it.
Old Oct 28, 2005 | 12:37 PM
Stngray's Avatar
Stngray
To Can a bad knock sensor cause poor emissions?
