what size socket for IAC 1988 L98
Old Oct 28, 2005 | 12:14 PM
brookman's Avatar
brookman
Default what size socket for IAC 1988 L98
What size is the socket needed to remove the IAC?
Old Oct 29, 2005 | 08:27 PM
brookman's Avatar
brookman
anyone?
Old Oct 29, 2005 | 08:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I always use an "adjustable" wrench on mine.
Old Oct 29, 2005 | 09:54 PM
Curveit's Avatar
Curveit
Same here.
Old Oct 29, 2005 | 10:29 PM
Pete K's Avatar
Pete K
Gm recommends a special kent moore tool that works perfectly. Most people do not use it because they are not easy to get. The sensor is never torqed on tight. A crescent wrench works perfectly.
Old Oct 30, 2005 | 12:03 AM
500hp's Avatar
500hp
If you have not bypassed the heater hoses running to and from the throttle body and choose not to take it off the car, you will need a thin wall 32mm socket. Preferably NOT a deepwell because of the lack of room down there. Good luck.
Old Oct 30, 2005 | 07:35 AM
thomastl's Avatar
thomastl
If you don't want to remove the TB so you can use an adjustable wrench - then get a set of needle nose vise grips. Just make sure they are a decent size. Clamp onto and turn. It is not very tight and should be able to loosen it this way. At least I was able to.
Old Oct 30, 2005 | 08:02 AM
Jet-Jock's Avatar
Jet-Jock
I used channel locks pliers both times on mine.
To what size socket for IAC 1988 L98
