Got a few questions
1. I have leaking injectors, does anyone have the contact information for Rich or Rick I cant seem to find his website and I have heard good things about his work.
2. When I come to a stop light and kick into neutral the RPM hold a steady smooth 900-100 RPM while coasting but as soon as the car stops it drops to a smooth 600-700 RPM. There is no stumble, vibrations, hesitation cold or hot what so ever. Is this normal or is something that I need to look into?
3. I do not have to pass emissions where I live but should I replace the converter due to leaking injectors (it looks pretty beat up as well)? The previous owner removed the pre-cats though I already have a y-pipe ready for replacement w/ pre-cats. Also can someone shoot/attach a picture of what the air pump line to the converter looks lilke from the factory. Someone welded the damn thing together. (Also please do not tell me to remove the converter (flame suit on) I want to keep it all stock and I feel that we might be getting inspections. Also does anyone recommend a good standard replacement main cat?
4. Does anyone know if there is a gasket kit w/ all the needed gaskets for the fuel injector removal & installation.
Thanks in advance for any help/advice.
Bob
Bob
# 2 sounds delightfully normal
as to # 3, are you sure it came with pre ctas? They are not needed to pass emissions, so you might want to avoid installing them
Don't know about anything else
Jack
3. I do not have to pass emissions where I live but should I replace the converter due to leaking injectors (it looks pretty beat up as well)? The previous owner removed the pre-cats though I already have a y-pipe ready for replacement w/ pre-cats. I want to keep it all stock and I feel that we might be getting inspections. Also does anyone recommend a good standard replacement main cat?
Catco or Random cat's are the popular ones
Bob
If you need any of the AIR stuff give a call to Contemporary Corvette (link on my site) as they vend new & used Vette parts and have a rather large Vette boneyard.
When you send the injectors to Rich don't forget the cold start injector. If you break any of the clips holding the injectors into the fuel rail leave the survivors on the injectors and Rich will replace any missing units. When you install the injectors apply a little motor oil to each O-ring to avoid nicking them on insertion.
