84 power door locks
Old Oct 29, 2005 | 01:25 AM
az-Thom's Avatar
az-Thom
Default 84 power door locks
power door locks work, not the unlock. replaced drivers side switch, no change. any thoughts or solutions.
Old Oct 30, 2005 | 08:24 AM
woody1243's Avatar
woody1243
When you replaced the switch did you check the wiring to see if you had a broken wire in the door area. I will check my manuals and see if there are two seperate relays for lock/unlock and get back to you.
Woody
Old Oct 30, 2005 | 07:28 PM
az-Thom's Avatar
az-Thom
Thanks Woody, I did check the wiring. I can hear the door switch click on both doors, but no action. Once in awhile it will unlock, but seldom.
Old Oct 31, 2005 | 12:30 PM
woody1243's Avatar
woody1243
there is a relay that controls both lock/unlock behind the center console information center. Now this is one relay that does both functions, it could be the unlock portion of this relay is carbon coated and not making very good contact but you said you hear the lock/unlock motors working in the doors so it may just be they are dragging enough in the unlock position to not operate properly.
Old Nov 3, 2005 | 05:49 PM
az-Thom's Avatar
az-Thom
thanks woody i'll check it out.
To 84 power door locks
