Help with removing rear knuckle needed
Old Oct 29, 2005 | 10:49 PM
montie98's Avatar
montie98
Default Help with removing rear knuckle needed
Hello,I folowed the dirrections in my Haynes manual and it still seems to be held on by something.Does the U joint have to be undone or something?The manual says that it will slide off the spindle but it wont even budge
Old Oct 29, 2005 | 11:16 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
What have you taken off?We need more info...what you removed or taken off will help us give better ideas what to do next.
Old Oct 30, 2005 | 12:19 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You need to remove the 3 T-55 torx bolts that thread into the backside of the bearing.... 1 lower camber arm bolt, 2 control arm bolts, 1 spring bolt, 1 sway bar end link bolt, lower shock nut, spindle nut and pin, and toe/tie rod nut, and unhook ebrake cable.
So if you have 8 bolts and 8 nuts removed, pull.
Old Oct 30, 2005 | 11:48 AM
montie98's Avatar
montie98
The bearing is connected to the knuckle so why should it not come out as one unit?
Old Oct 30, 2005 | 12:46 PM
Aggravated4life
If the halfshaft/yoke is still stuck in there,and you removed everything,youre prob gonna need to use a Puller to push the yoke out of the bearing.Thats all I can think of since Im not entirely sure in my head what you did/didnt remove.
Old Oct 30, 2005 | 03:13 PM
CentralCoaster
Thanks for correcting me. The bearing splines might just be sticking to the axle with surface rust.
Old Oct 30, 2005 | 11:10 PM
montie98's Avatar
montie98
Yes everything is removed except for the bearing .Here comes the puller and some PB Blaster
To Help with removing rear knuckle needed
