Too Rich!
Old Oct 31, 2005 | 10:10 AM
95BlueBomber's Avatar
95BlueBomber
Default Too Rich!
I have a 95 LT1, No Cats, No emissions equip., 3"SLP Exhaust w/xpipe, Claw intake, and nitrous plugs. My car is running very rich. The nitrous plugs are colder, but would this be affecting my air/fuel? At least enough to be noticed? I am thinking of getting LT1 Edit, is there anything I can do with that to lean the car out a bit? What about a fuel pressure regulator? Would that help lean it out? Any help would be appreciated!
The Bomber
Old Nov 4, 2005 | 08:42 AM
VAHROOM's Avatar
VAHROOM
Default I don't have an answer as to how to solve your issue.
I don't have an answer as to how to solve your issue, BUT, if you are talking about richness during less than WOT then a regulator won't help. Well unless you have bad fuel pressure issues it won't. The computer looks at the O2 sensors and tells the injectors to give the amount of fuel you need. If the O2's are funky, that may be part of it.
How did you discover you are running rich?
Old Nov 4, 2005 | 09:43 AM
95BlueBomber
Ok its rich across all tps positions. Especially under WOT. Over 900mv at the O2 sensors. What adjustments to the MAF can I do to correct? Or does something else need to be changed?
Old Nov 4, 2005 | 12:40 PM
gbody5's Avatar
gbody5
O2 volts don't tell the whole story. Check your BLM's at part throttle and just before Power Enrichment.
Old Nov 4, 2005 | 01:22 PM
95BlueBomber
Ok BLM @ WOT is 135 135
@ 34.5% 132 136
@ 20.4% 125 125
75% Of the time the BLM is in the 130's.
Old Nov 4, 2005 | 01:41 PM
FD2BLK's Avatar
FD2BLK
@ 34.5% 132 136
@ 20.4% 125 125
How are you checking this? THe ECM locks the BLM's at 128 during WOT.
Part throttle BLM's in the 130's are not all that bad and the ECM is correcting for them. Just looking at the two numbers you have posted with no kpa data I would say you are fine, a tad rich but as I said in the range the ECM will correct for.
Old Nov 4, 2005 | 02:06 PM
95BlueBomber
tts datamaster. I am new to the tuning world and kind of confused on how it all works. I am having problems with the richness and spark knock. in a 4 mile drive i picked up 9600 knock count.
Old Nov 4, 2005 | 02:18 PM
gbody5's Avatar
gbody5
Yea, you're not too far off, ECM is doing it's job. Above 128 is actually lean, below is rich. I don't use Datamaster and have an L98, but knock counts do not mean timing retard. You're probably OK there too. If you hear pinging and are already using 92/93 octane then you may have a tuning issue, like too much timing. Stock calibration or do you have a modified .bin?
Old Nov 4, 2005 | 02:42 PM
FD2BLK's Avatar
FD2BLK
[QUOTE=gbody5]Yea, : Above 128 is actually lean, below is rich.QUOTE]
True I was looking at the 125's because he was complaining of a rich condition. I also just noticed you state "No emissions equip". Does this include the EGR removed, did you have the ECM programed to compinsate for this? If not you need to because the ECM is correcting timing trying to compinsate for the EGR gasses that are now not there.
Old Nov 4, 2005 | 03:07 PM
95BlueBomber
No EGR I dont know what to adjust for the EGR being gone. Does anyone have a .bin file that is close to what I have that I could simply upload and be done with it? Thanks!
Old Nov 4, 2005 | 07:49 PM
FD2BLK's Avatar
FD2BLK
For $60, $50 if you think it is a one time shot you can get a good tune with great suppotrt. Shoot Ion an e-mail. I use him for any LT1 mail order stuff I do and he is prety good. The F-body croud uses him quite a bit also with great results.
http://www.madz28.com
Old Nov 4, 2005 | 09:49 PM
Morley's Avatar
Morley
Set the EGR enable temp to 255.
To Too Rich!
