"Motor Up??"
Old Nov 1, 2005 | 11:56 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Default "Motor Up??"
Aparently Motor Up is ment to be one of the best oil aditives available. Has anyone ever used it? Anyone had any issues from using it? I put some in my 94 the other day and it seems to have smoothed it out abit.
Old Nov 1, 2005 | 12:17 PM
Nathan Plemons's Avatar
Nathan Plemons
Generally you'll find that any additives are looked upon poorly here.
Old Nov 1, 2005 | 12:19 PM
Nathan Plemons
http://www.ftc.gov/opa/2000/03/motor.htm
Old Nov 1, 2005 | 01:22 PM
Casethecorvetteman
Originally Posted by Nathan Plemons
Very interesting thanks Nathan, i remember the Motor Up ads we had on TV here in Australia very late at night back around 2000-2001, and while some of it is definate , i must say that after adding the bottle, the engine runs ever so slightly smoother and IS without a doubt quieter. For the price i paid for the stuff, it was a bargain anyway, (dirt cheap here cause it never took off and shops that had it back then are over stocked) So while i will say it is definatly not going to produce miracles, i did notice a change(even as minor as it was). Thanks for your input mate
Old Nov 1, 2005 | 05:44 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The human mind is very susceptible to suggestion.
Larry
code5coupe
Old Nov 1, 2005 | 08:11 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
According to a lot of corvette owners, mechanics and even the playboy advisor... Oil additives claim to do what syntetic oil already does.
I did not listen, I added additives and now I have a F$#@@ing front oil leak.
Old Nov 2, 2005 | 12:28 AM
Casethecorvetteman
I allready had that, be f***ed if i can find where it is coming from though....
Old Nov 2, 2005 | 01:08 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
What about this stuff Motorsilk
I can't find a lot on it but all I read says good things.
Old Nov 2, 2005 | 02:16 PM
GlennS87's Avatar
GlennS87
Try this site for questions on additives.
http://theoildrop.server101.com/ubb/...?ubb=forum;f=5
Old Nov 3, 2005 | 01:23 AM
Casethecorvetteman
Havent heard of that stuff yet, I know of another oil stabilizing aditive available here LUCUS is the brand name...
http://theoildrop.server101.com/ubb...p?ubb=forum;f=5
Thanks mate, but the link is no good!!!
Old Nov 3, 2005 | 07:35 AM
Greg Gore's Avatar
Greg Gore
Default Additives- Don't Do It!!
Is that the infomercial where they ran it with the additive for a while then took the oil pan off and ran a few laps around a track or is that the one where they had an engine on a test stand and took the oil pan off and after starting it up they sprayed the crankshaft and rods with a firehose while revving it up? You would be mostly buying in to a bill of goods with any of this stuff. Truthfully...oil today is an engineered package and if it needed something additional the engine manufacturer would have required it and the oil engineers would have already put it in. I don't know of any additive that is not mostly "snake oil" and your best hope is it won't do any damage if you decide to try it.
Old Nov 3, 2005 | 11:00 AM
GlennS87's Avatar
GlennS87
I just tried it and it worked. Maybe the site was down when you tried it.
Old Nov 4, 2005 | 01:38 AM
Casethecorvetteman
Must have to be a member of that forum. Cause unless its going down every few hours when the sun comes up in Australia i cant get into it!!
Old Nov 4, 2005 | 08:55 AM
aboatguy's Avatar
aboatguy
Try this one
Bob
Old Nov 4, 2005 | 10:31 AM
GlennS87's Avatar
GlennS87
Yes, I believe that you have to register to be able to view the forums. It doesn't cost anything and I find it pretty interesting.
Old Nov 4, 2005 | 02:15 PM
Casethecorvetteman
Originally Posted by aboatguy
Try this one
Bob
Yep, that one worked!! thanks mate. Dont spose any of you know what this GC is they are talking about eh???
Yeah mate, thought so, i ended up getting in in the end!!
Old Nov 4, 2005 | 02:43 PM
GlennS87's Avatar
GlennS87
GC I believe is German Castrol. It's not Syntec but it is synthetic. Seems a number of people on that board sing its praises.
This is a thread over there with common acronyms:
http://theoildrop.server101.com/ubb/...c;f=1;t=009552
To "Motor Up??"
Old Nov 4, 2005 | 05:29 PM
TR Vert's Avatar
TR Vert
Oil Additives....
The biggest problems is that many chemicals can react negatively with one another causing unexpected results.... viscosity changes, foaming,
precipitates that can plug the filter, sludge,
It's not worth it... just by a good quality oil to start
Old Nov 5, 2005 | 04:41 AM
Casethecorvetteman
Cant say ive seen it.
Originally Posted by 88redvert
Oil Additives....
I only use the best quality i can get off the shelf at the time, normally Castrol Synthetic R 5W 30.
Old Nov 5, 2005 | 05:09 AM
Casethecorvetteman
what about this stuff??
http://www.royalpurple.com.au/
