I have a 1990 coupe and I want to change the fuel filter. The Haynes manual says to pull the fuse marked FP in the fuse box and run the engine out of gas to releve the fuel pressure, but I don't have such a marked fuse. I figured that I'd releve the fuel pressure by opening up the fuel rail schrader valve. But when I did this and pressed on the needle valve I only got a drop of fuel. the car was cold, having sat all night, but I expected more pressure. Was this normal?
Nuthin sez lovin' like a flammable liquid running up past your elbows and soaking your armpit hair.
Seriously, though, put that corner of the car on a jackstand. Put a pan under it. Have some old rags ready and take it slow. It would be a bummer to mess up the fuel line. I detached the tank side first. Then I let it drain for a couple minutes before disconnecting the engine side.
Tip: Get the fuel lines in place and the filter loosely mounted to the body before tightening/clipping.
I just changed mine. My '85 had the factory filter on it! 65k & 20 years? It also has factory belt, plugs, wires, cap, and coil. I assume it has factory rotor and HEI. Guess what I'll be doing this winter? I wish my garage was attached.
I pulled the fuse on my 92 and let the engine run until it starved. I'd say I only had about 1/4 cup of gasoline leak out of the line after that, but you do what you gotta' do to get 'er done!
Thanks guys. It just seemed strange that when I opened the schrader valve only a drop came out. I expected a big pressure release. By the way, does anybody know what fuse on a 90 disables the fuel pump?
From: A place where chickens can cross the road without having their motives questioned
The fuse on my 88 was labeled as something else too. It was something like FR (fuel regulator?) or something to that effect. I just know that when I pulled it the car ran for a few seconds and then died and I didn't have a ridiculous amount of fuel run out when I disconnected the fuel lines.
90 has some fuses up under the passenger knee bolster... pita location for a number of things. Like power locks etc. After all night most pressure will drop. That is why you hear the pump when you turn the key before hitting start...
