climate control on C4 corvette not working
Old Nov 2, 2005 | 08:13 PM
rja614's Avatar
rja614
3rd Gear
Default climate control on C4 corvette not working/1990 ragtop
The climate control system failed on my 1990 ragtop completely. No temp or fan speed display, but it is lit. There are no fans, heat or A/C. None of the controls work. It was working fine, then just quit after I took a little ride, turned the engine off and then restarted it. Then I noticed nothing was working. In addition, the radio antennae won't go down. Any suggestions or ideas?
Old Nov 2, 2005 | 09:26 PM
dmyers's Avatar
dmyers
From: A place where chickens can cross the road without having their motives questioned
Start checking fuses.
Old Nov 3, 2005 | 01:05 PM
SunCr's Avatar
SunCr
You need to tell us what Year.
Old Nov 3, 2005 | 01:10 PM
ckd's Avatar
ckd
Theres a simliar post that popped up last night. It had the same problem, if your speakers aren't working as well I'd assume a fuse was blown like mentioned above as they are on the same circuit.
Old Nov 3, 2005 | 08:07 PM
rja614's Avatar
rja614
3rd Gear
I put a new fuse in the A/C and Radio circuit and still have the same problem. Are there any other fuses besides the ones on the passenger side dash, by the door?
To climate control on C4 corvette not working
