1989 ZF6 speed shifting problems
Old Nov 3, 2005 | 10:03 AM
gmracing's Avatar
gmracing
4th Gear
Default 1989 ZF6 speed shifting problems
Having intermittent trouble when shifting from first to second gear. It seems to get stuck between gears. It comes out of first but won't let me shift to any other gear until I shake the shifter then it works. Any Ideas?
Old Nov 3, 2005 | 11:03 AM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
Are you sure it's not the CAGS working?
Old Nov 3, 2005 | 11:43 AM
gmracing's Avatar
gmracing
4th Gear
Default Thanks
New owner, wasn't aware of this feature. I don't really like it but at least I don’t need to pull the tranny.
Old Nov 3, 2005 | 11:45 AM
HTRK-1's Avatar
HTRK-1
Just unplug it and seal off the connectors....Problem solved.
Old Nov 3, 2005 | 02:13 PM
Nathan Plemons's Avatar
Nathan Plemons
I bought my car on a Monday night. On Tuesday night I bypassed the CAGS. It's the most irritating "feature" ever devised if you ask me.
Old Nov 3, 2005 | 02:19 PM
vettmike's Avatar
vettmike
Make sure the clutch fluid is at the correct level, you might consider flushing and bleeding the system.
Since the car is new to you, it would not be a bad idea to change all fluids and everything freash and at a baseline.
vettmike
Old Nov 3, 2005 | 06:16 PM
LD85's Avatar
LD85
if you double pump the clutch,,,does that help?
Old Nov 3, 2005 | 07:15 PM
gmracing's Avatar
gmracing
4th Gear
Default Mystery solved
It's the CAGS crap. I will be disabling it soon.
Old Dec 26, 2005 | 10:32 AM
96CEwGEARS's Avatar
96CEwGEARS
I searched for a kit to disable this. It exists for the C5 and C6. Same kit for a C4? If not, would someone provide a link for a C4 kit supplier?
I agree...what a pita feature.
Thanks.
Old Dec 26, 2005 | 11:34 AM
JCD's Avatar
JCD
MaMo results $16
Eckler's $12
Watch out for shipping & handling costs, that's where eckler's makes their $$. It's like a retroactive vette tax.
Old Dec 26, 2005 | 11:36 AM
JCD's Avatar
JCD
Thanks.
PS The 1996 kit is different than the other C4 kits, so you'll need to do your own search.
Old Dec 26, 2005 | 12:33 PM
96_LT4_FE1's Avatar
96_LT4_FE1
Ditto I bought one that was a "generic" and it listed itself thru '96, but, although the plugs looked alike, they were keyed different. luckily I could shave the keys off with a knife and make it work. I got mine from JEGS and paid too much for it.
live and learn, I guess...
»keith
Old Dec 26, 2005 | 03:56 PM
96CEwGEARS's Avatar
96CEwGEARS
MaMo results $16
Eckler's $12
Thanks, JCD. Just what I needed.
And the MaMo link has the different setup for the '96.
Thanks all.
To 1989 ZF6 speed shifting problems
