Manual Trans Dip Stick?
Old Nov 3, 2005 | 04:34 PM
Black85Autocross's Avatar
Black85Autocross
Default Manual Trans Dip Stick?
I want to change the tranny fluid in my 4+3 and change the filter in the o/d but I can't find the dipstick to see if how much to put in when I'm done. I though it was supost to be behind the valve cove on the passanger side. A pic may help
Old Nov 3, 2005 | 05:03 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I've never seen, or heard of, a dipstick for a manual transmission.
Larry
code5coupe
Old Nov 3, 2005 | 05:12 PM
JCAIRE2's Avatar
JCAIRE2
Larry
code5coupe
He's talking about the overdrive assembly on the 4+3. I don't know whether it has one or not, but I believe it does.
Old Nov 3, 2005 | 05:18 PM
DanZ51's Avatar
DanZ51
Nope. It's filled through a pipe plug on the side. There's no torque converter or such, so it's pretty much fill 'til it runs out the hole. If you're "****" recheck it again after a few miles of OD use.
Old Nov 3, 2005 | 05:23 PM
Black_Vette's Avatar
Black_Vette
All you need to do is fill the fluid from the bolt hole on the side of the Overdrive Unit until it starts pouring out. Its easy to fill I just did this about 2 weeks ago on my 4+3 works great.
Old Nov 3, 2005 | 05:52 PM
Black85Autocross
Thanks for the info. I was looking through a shop manual and it showed a pic of the dip stick. Though maybe my was broken or something. I found the plug hole so it should be no problem. Again thanks
Old Nov 4, 2005 | 02:48 AM
Socky's Avatar
Socky
What kind of fluid should be used in the O/D unit and the trans. Thanks
Old Nov 4, 2005 | 03:45 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I've always filled it while the car is running on jackstands. This is the easiest way to make sure you're filling up the cooler lines and get everything in that GM calls for.
I've thought putting a fill nipple on the top cooler line would be a good idea, but then I just tore them out. And the transmission too.
To Manual Trans Dip Stick?
