Gas milage computer!
Old Nov 4, 2005 | 07:07 AM
gdaddee's Avatar
gdaddee
Default Gas milage computer!
I haven't reset my average mpg meter in more than 6 or 8 tank fulls. It has been reading 20.6- 20.8 the whole time. About 800 miles of this is freeway miles so it takes a long time to change even 0.1 mpg. This morning on the way to work in less than 2 miles the mpg jumped to 24.6! Has anyone had a similar experience? I reset it to see what happens next.
Old Nov 4, 2005 | 07:24 AM
runner140*'s Avatar
runner140*
No.
Old Nov 4, 2005 | 07:28 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
On the highway, mine reads 32.00 or higher depending on the actual road.
I have gone over 500 miles on one tank.
Old Nov 4, 2005 | 03:40 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I think he is talking about the jump in MPG, what happened is the mileage counter used by the computer only goes to 999.9 miles, so when it starts back over at 0's it started recalculating like you had just reset it. Atleast, that is what I was told when mine did the same thing.
Old Nov 4, 2005 | 05:26 PM
gdaddee's Avatar
gdaddee
Thanks for the input. That could be it.
Old Nov 4, 2005 | 06:50 PM
okies93's Avatar
okies93
St. Jude Donor 06
what're driving a neon? if you are getting 500 on a tank then i really need to change my plugs
Old Nov 4, 2005 | 07:33 PM
cmontel727's Avatar
cmontel727
I'm lucky if I get 350 miles out of a tankful!
Old Nov 4, 2005 | 08:08 PM
Lichen's Avatar
Lichen
Those things can be pretty unreliable. Need to start doing your own calculations at the pump to see how accurate it is.
Old Nov 4, 2005 | 11:17 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
30.2 MPG average for the trip to Carlise and home. 960 miles on little over two tanks. That's the top of the third tank.
Averaged 34.1 for the first 380 miles.
I've manually caculated the MPG against the computer and it's usually within +- .1
To Gas milage computer!
