1991 L98
Old Nov 4, 2005 | 10:31 PM
stonemo's Avatar
stonemo
Default 1991 L98
Ive got a 1991 coupe with a L98. Was wondering does this motor have hyd roller lifters on it? What years did they put roller valve train in Corvettes? Thanks
Old Nov 4, 2005 | 11:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Yes it has a roller cam; I believe that came in '87, for sure '88 had it too.
The #113 heads ('88-'91) came with non-hardened guide plates and self aligning pressed rockers on 3/8" studs (7/16" threads).
Old Nov 4, 2005 | 11:14 PM
vader86's Avatar
vader86
roller started in 87
Old Nov 5, 2005 | 08:15 AM
AKS Racing's Avatar
AKS Racing
I think the roller cam (along with Al heads) started in '86 on the roadsters only. This package went across the board in '87.
Old Nov 5, 2005 | 09:59 AM
stonemo's Avatar
stonemo
Thanks for the info guys.
Old Nov 5, 2005 | 11:34 AM
vader86's Avatar
vader86
No, roller started in 87.
Aluminum heads in late 86.
Old Nov 5, 2005 | 11:55 AM
stonemo's Avatar
stonemo
Didnt mean get any arguments going. So my 91 coupe does have roller lifters in it, correct me if im wrong.. That would mean that it has a roller cam, that would require a bronze gear on the distributor? Ive read somewhere that if you put a roller cam and lifters in a small block chevy that you had to replace the distributor drive gear with a special one to keep it from eatting up the cam. That would be good to know if one ever decided to change out the stock distributor. Thanks
Old Nov 5, 2005 | 12:18 PM
CFI-EFI's Avatar
CFI-EFI
Four posters have been unanimous. What is in question that could need correcting?
If you ever replace the distributor, use the stock distributor gear (or equivalent) to work with the stock cam.
RACE ON!!!
To 1991 L98
