89 headlight bushing replacement problem
Old Nov 5, 2005 | 11:59 AM
Vett-eight-nine's Avatar
Vett-eight-nine
Default 89 headlight bushing replacement problem
I'm trying to do this on the driver side without removing the headlight assembly or the motor. I've accessed the plastic gear and would have no problem if I could just get the thing to come out of the housing!
The plastic gear has on top of it an aluminum disk which looks nothing like the pics in Corvette Fever. How do I get the gear off the shaft? I don't know how forceful to be or the tools to use.
Thanks.
Old Nov 5, 2005 | 01:20 PM
Casethecorvetteman's Avatar
Casethecorvetteman
I just did both of them on my 94, which are the same as yours. The easiest way is to remove the whole assembly from the hood, that way you will see what you need to remove screw wize. The aluminum disc you are refering to has a shaft going through the nylon gear, and is held in place on the other side by the rectangular piece of aluminum, there is a pin you need to push out of that in order to remove the disc, then the gear will fall out easily on the driver side. I personally DID NOT use new bushings, as this is only going fail again in time. I used steel shims to make a snug (not over tight or the gear will warp) and even fit between the gear and the drive disc. Either way you go, once you have that done, simply put it back together in the reverse order you pulled it apart. You dont need to remove the motor and from what ive heard i wouldnt recomend it either!!
Old Nov 5, 2005 | 01:22 PM
Casethecorvetteman
right hand side is a little more complicated due to the backwards installation of the gear and drive disc assembly. Youll know what i mean when youre in there, its not much different, just requires abit more jiggery pokery to get the gear in and out.
Old Nov 5, 2005 | 01:46 PM
Vett-eight-nine
Is the "pic" you're talking about a type of pin, locaated between the headlight and the motor, actually holding the motor onto the whole assembly. I believe I can see that and can get to it.
I think this pin and the 3 torx screws actually hold the motor assembly onto the headlight assembly. I want to be on the right track.
Old Nov 5, 2005 | 01:47 PM
Vett-eight-nine
Oh, btw, Case. From what I 've read, the bushings are the sacrificial pieces, this is why I'm inclined to replace with same (or nearly- I'm looking for a cheap fix).
Old Nov 5, 2005 | 01:54 PM
Casethecorvetteman
Surely is ment to be PIN mate yep, not pic!!! Sorry bout that.
They are indeed sacrificial, how ever not needed in my opinion. The bushes cost money, and the steel shims with cost you next to nothing. You might have something lying around the house you can use and then its free!!!
Old Nov 5, 2005 | 01:55 PM
Casethecorvetteman
Thats afirmative.
Old Nov 5, 2005 | 03:27 PM
Scott-89's Avatar
Scott-89
I agree. It was much easier to remove the whole headlight and do it on a bench. Just put down a soft cloth to set it on so you don't scratch up the paint.
I removed the bracket that holds the connections for the headlight so I could remove the clips from the back. If you have a set of bent needle nose pliers it might be doable without taking the bracket off, but I didn't have a set and the bracket is only held on with 3 screws.
Once the headlight is out, I had to just loosen the torx screws on the bracket so I could move the motor the get to the bottom torx screw that holds the motor on.
I also used some grease to hold the shims in place when I put it back together.
Old Nov 5, 2005 | 10:31 PM
Vett-eight-nine
Thanks for the replies, guys. I'm going to give it one more try with the headlight in place ( I just don't want to fool with the re-alignment) and then, I'll do it the right way.
Old Nov 6, 2005 | 02:08 AM
Casethecorvetteman
Its **** easy to put them back on the hood, mark the 4 bolts around the edge of their washers, and then line up with that when you re-install it, just check youve tightend the main 4 bolts(dont worry too much about the bottom 2) and checked for an even gap all round from the top side of the hood before you test your lights for function.
To 89 headlight bushing replacement problem
