Self aligning rockers for L98
Old Nov 6, 2005 | 10:51 AM
FostersPerformance's Avatar
FostersPerformance
Default Self aligning rockers for L98
Do they need them??? Its a 1988 L98..I didnt think they needed them.I thought only aftermarket heads required them.
Old Nov 6, 2005 | 11:35 AM
JackDidley's Avatar
JackDidley
If it has guideplates you dont need self aligning rockers.
Old Nov 6, 2005 | 11:36 AM
FostersPerformance
Ok see i didnt know that either..Why is that??
Old Nov 6, 2005 | 11:37 AM
FostersPerformance
What about offset rockers?? Same thing?
Old Nov 6, 2005 | 01:19 PM
CFI-EFI's Avatar
CFI-EFI
If it has REAL guide plates, not just those non-hardened assembly line aids.
There has to be SOME means of keeping the tip of the rocker arm over the valve stem.
RACE ON!!!
Old Nov 6, 2005 | 01:33 PM
TheCorvetteKid's Avatar
TheCorvetteKid
'88 L98s came equipped with self-aligning rockers and non-hardened guide plates from the factory.
Old Nov 6, 2005 | 05:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
So, yes, the stock L98 (well, at least '88-'91) "needs" self-aligning rockers to keep the rocker tip over the valve tip.
Old Nov 6, 2005 | 05:31 PM
87 rag's Avatar
87 rag
What did an 87 come with?
Old Nov 6, 2005 | 05:44 PM
TheCorvetteKid
Probably just hardened pushrods and hardened guide plates with non-self aligning rocker arms.
These have been used for years on SBCs - they use the guide plates to help maintain rocker alignment. Has worked well pretty much since the inception of the small block.
Old Nov 6, 2005 | 05:54 PM
87 rag's Avatar
87 rag
Can you use self aligning when originally the car came with non self aligning? What are the pro's and cons?
Old Nov 6, 2005 | 06:09 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I wouldn't.
You don't want the rocker to be forced into alignment in two different places (at valve and guide plate) because if they don't agree with eachother on where the rocker should be, it can bind and bend the pushrods.
Some do it anyways and get away with it.
Old Nov 6, 2005 | 06:16 PM
87 rag's Avatar
87 rag
Originally Posted by CentralCoaster
I wouldn't.
I was hoping you wouldn't say that. Do the guide plates come out?
Old Nov 6, 2005 | 06:24 PM
CentralCoaster
Dunno. On my iron head, there are no guideplates, the head itself has guides cast into em, and the rockers are non-s.a.
Did you already order the s.a. rockers? If so, I'd just take the guideplates out, assuming it's doable.
Old Nov 6, 2005 | 06:28 PM
87 rag's Avatar
87 rag
That's exactly what I did.
I think I have aluminum heads. I'll see what's in there when I open it up this winter.
Old Nov 6, 2005 | 08:27 PM
65Z01's Avatar
65Z01
The Al heads came in late '86 and the roller block in '87; I would bet that those Al heads came also came with non hardened guide plates & self aligning rockers, like on the later #113 heads.
In that case you can install self aligning RRs but, if you go above the stock 1.5:1 ratio, you need to be sure that the push rod does not contact the guide plates.
Yes the rocker studs come out, they have a 7/16" thread with 3/8" rocker shaft. If you remove the OEM non hardened guide plates you will need same thickness washers under the rocker stud bases. This is why I went with non self aligning RRs as I would likely have to pull the studs in either case. Of course you could just file the stock guides open a little to avoid contact with the push rods.
Old Nov 6, 2005 | 08:36 PM
87 rag's Avatar
87 rag
Thanks Jim, I'm going to email you to run that by me again when I get to the install.
Jeff
Old Nov 6, 2005 | 09:39 PM
MrNuke's Avatar
MrNuke
I put on a set of Crane Cams Self aligning roller rockers few years ago on my '85 L98..
The stock iron heads had some nasty slots cut into them for the pushrods, stock 'guideplates' I guess.
Old Nov 7, 2005 | 06:12 AM
rodj's Avatar
rodj
'87 (and the late '86 with same 128 alum head I believe) have self aligning.Changed mine to non self aligning and proper guideplates after getting good deal on some Comp Cams magnums from a Forum member.
As stated above does not matter what you run (non or self aligned )so long as parts are compatible.
Old Nov 7, 2005 | 10:02 AM
87 rag's Avatar
87 rag
Thanks Rodj.
That makes me feel better.
To Self aligning rockers for L98
