Coolant leak driping on exhaust manifole!
Coolant leak driping on exhaust manifold!
I'm getting a lot of smoke (or maybe steam) off the left exhaust header. I have a 1987 coupe with a new engine. I have installed TPiS headers. Upon investigation with a flashlight while the engine was running, it appears that the coolant is driping off the back of the header flange (Between the head and the flange). Some of the lower head bolts are wet and there is a significant puddle under the car after a few minutes of running.
Do the exhaust manifold bolt holes in the head extend into the water jacket? I used anti-sieze compound on all bolts but I didn't use any sealent. Can anyone think of some other explination of where the water would be coming from,,,,runing down the back of the header flange?
that would make me wonder if a head bolt is loose or if there is a crack in the head.
on the right side, there is a small coolant hose... also, check to be sure the intake isn't leaking.
in short, this does not sound good at all.
My thoughts exactly, bogus! I'm pretty sure all the head bolts are tight. I could see droplets of coolant driping from the header flange onto the lower head bolts. There is a small leak around the thermostat housing, but it doesn't look like enough to match what I am seeing run down the headers. My worst fear is a cracked head behind the exhaust bosses. I guess I'll have to remove the left header and see what's up. Like you said, It can't be good....
What would I look for to determine if it is the intake gaskets?? Would I see water running out the exhaust or something?? I have had one sucking air before on a carburated car and it exibited rough, uncontrolable idle.
Help me out here CFI-EFI.
Received 3,043 Likes
St. Jude Donor '05
Originally Posted by CFI-EFI
I'd bet on the infamous intake manifold gaskets.
RACE ON!!!
RACE ON!!!
RACE ON!!!
