FJO mini controller
Old Nov 7, 2005 | 08:05 PM
FD2BLK's Avatar
FD2BLK
Default FJO mini controller
Just got a new toy in the mail a FJO progressive mini controller. This thing is way to cool and I now can't wait to get the darn nitrous installed (waiting on my solenoids to get back). It was only $200, about the cost of a TPS and Window switch.
Check out some of features
TPS controlled window switch, (no need for a mechanical switch here)
First gear lock out
RPM cut off
RPM trigger
Two stage progressive control (I will only be using stage one for the moment)
Time based or RPM based progressive curve so you can bring the nitrous on progressively and you can use software to adjust the curve with. The software allows you to smooth and raise progression lines with in the curve to adjust the nitrous progression instead of a straight curve selection.
Old Nov 7, 2005 | 09:46 PM
zelement's Avatar
zelement
FJO makes good stuff.
i have an FJO wide band O2 gauge that I bought. unfortuantely it didn't work with my DFI computer.
I still have it. would it work with that controller?
Old Nov 8, 2005 | 11:07 PM
FD2BLK's Avatar
FD2BLK
Nope, no O2 input into this one but there are others it should work with
Here is one that I think would and mabey i should have went with but just decided to go name brand
http://www.harrisspeedworks.com/shop...cat=338&page=1
This one works wth the FJO wideband but it is a bit pricey and you would have to call to see if it would work with yours.
http://www.nitrousoutlet.com/outlet/...&section_id=24
To FJO mini controller
