Okay so I'm trying to figure out a way to make a street legal supercharged 383. I'll be using a remote mount egr fitting. (It's kind of cool it lets you mount an egr on any engine.) So really the only thing I need to figure out is an A.I.R. pump. We have a visual inspection here in PA but not the sniffer test "yet". So my question is can I use an electric smog pump from an LT1 on an older style engine? And if someone could explain to me how the LT1 A.I.R. system works. I know it has valves that open at certain times but I don't know when or why.
I don't have the FSM here to look this up, but to the best of my recollection, the AIR system on the LT1 is triggered by the ECM at startup, runs for either a fixed time or until the system goes closed-loop (IIRC, it's a fixed time), then the voltage to the pump is removed, shutting it down.
You could probably approximate the performance of the LT1's system by connecting the pump's power feed to a timer circuit on your car.
Thanks for the replies. As far as the visual side of it goes I'm not sure either. I know in PA you can swap in a newer style engine and use all the new emissions stuff. This is a newer style block "one piece main" so I'm basically hoping on fast talking the mechanic.
Also are there problems with letting the pump run all the time?
I can't comment on what PA's requirements are WRT visual inspection (we don't have to lift the hood on our C4s here in Maryland), but I'd think you could inquire or research this to see what's permissible in PA before settling on this as a solution.
Could be that what you're proposing is acceptable, thus no need to sweat it when you take the car to the proctologist. If you can get somebody in authority to give you written confirmation that it's legal, you're all set...
I can't say for sure, but I doubt the pump is designed for continuous-duty service, as that wasn't part of its intended operating requirements. You should be able to come up with a solid-state timer circuit that will take a 12v input and switch it on at power-on, and off after 'n' minutes. Ask an electrical engineer or electronic tech to help you with it, if you can't find a commercial off-the-shelf solution.
