Need to determine true diff. ratio
Old Nov 8, 2005 | 05:07 PM
jispr's Avatar
jispr
Default Need to determine true diff. ratio
I just signed on here tody and am amazed by how many posts and replies there are!! Anyway 6 year owner of a 1993 lt1 whose spec sheet says I had/have a 2.59, the carrier says 2.73 and the previous owner told me 3.80. So how do I determine the present ratio. If it's
by turning the tire and counting the driveshaft, the shaft turns just about 3 and 3/4 turns for 1 turn of the tire. Its' getting noisy back there maybe more so than just the diff, but all in good time.
Thanks Jim Speer Atlanta Area
Old Nov 8, 2005 | 05:09 PM
SJW's Avatar
SJW
If you're getting 3 & 3/4 turns of the driveshaft to a single turn of the halfshafts, it's definitely not 2.59 or 2.73. Should be very close to what the previous owner told you.
Surest way to determine it is to count the teeth on both the ring and pinion gears, but that, of course, requires that you have the case open.
Welcome to the Forum.
Be well,
SJW
Old Nov 8, 2005 | 05:11 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The "3 and 3/4 turns" you see match up with the 3.80 that the PO reports. I've never heard of 3.80 gears, but that doesn't mean a lot...
Larry
code5coupe
Old Nov 8, 2005 | 06:36 PM
CFI-EFI's Avatar
CFI-EFI
Probably 3.73:1. Make sure that BOTH rear tires make exactly one revolution while you are counting the driveline turns.
RACE ON!!!
To Need to determine true diff. ratio
