Display DTC codes
Old Nov 9, 2005 | 10:09 AM
Preacher94's Avatar
Preacher94
Default Display DTC codes
Does anybody know how to display the stored DTC (Diagnostic Trouble Codes) via the instrument panel? I have a 1994 coupe.
Old Nov 9, 2005 | 10:23 AM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default adfgsdfg
adsfbsdfg
Old Nov 9, 2005 | 10:42 AM
Red Dwarf's Avatar
Red Dwarf
Go to c4vettes.com
Go thru the options on the site . It has the basic info for your 94.
Old Nov 9, 2005 | 03:44 PM
Preacher94's Avatar
Preacher94
Actually - it is c4corvettes.com and the site isn't working. It says it was last updated in 2003.
Other suggestions?
Old Nov 9, 2005 | 08:09 PM
tempest's Avatar
tempest
i have a 92, but the following should apply for your 94. this is some info i provided to a forum member a while back.
First get a 2-3 inch length of wire to short out some leads. (I just used speaker wire.) Turn ignition off. If you have the 12-pin OBD-II -style connector (our cars are OBD-I), take your wire and ground pin G by shorting it to pin A. If you are looking at the connector, the pinout is
FEDCBA
GHJKLM
so it would be the upper right to lower left. If you don't have the 12-pin, check the 'Net for the pinout.
Get a pencil and paper handy and turn ignition on. Pay attention as it will immediately cycle through codes for, in order, the CCM (module 1), ECM (module 4), ABS/ASR EBCM (module 9). The odo shows the module and the speedo shows the codes. If you miss it the first time, just key off, wait a few seconds and key back on. When I just did mine I had code 72 stored in the CCM, even after I've disconnected the battery numerous times.
To clear codes in your CCM, wait until the codes cycle and the odo reads "1.0". This means the CCM is waiting for input. Press the TRIP/ODO button a few times until the numbers turn to 1.7. (You can go backwards by pressing GAUGES) Press ENG/MET until the speedo shows "---", then key off. Wait a few seconds and turn ignition back on to see if the codes have
cleared.
FYI you can clear codes for the other modules - just press TRIP/RESET or FUEL RESET to change the module, Change the number after the decimal so you get "X.7" and press ENG/MET as above. Key off, wait, and key on. Don't forget to take your wire out after you key off.
there is also a way to display codes via the flashing of the check engine light on the cluster, but i forgot which pins to short for that. i think it was A&B, but don't quote me on that.
Old Nov 9, 2005 | 08:19 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I think you may have a 16 pin connector like my '95. If so, jump pin 4 to pin 12 which are the fourth pins from the left in both rows.
Old Nov 9, 2005 | 08:27 PM
FD2BLK's Avatar
FD2BLK
close 16 pin and 4 to 12 jumper is correct
1_ 2_ 3_ 4_ 5_ 6_ 7_ 8
9 10 11 12 13 14 15 16
Old Nov 9, 2005 | 11:03 PM
Preacher94's Avatar
Preacher94
Yep. 4 to 6 is correct. I came up with two codes:
C 12
H62
Anybody know what they mean????
Old Nov 10, 2005 | 12:56 AM
Jet-Jock's Avatar
Jet-Jock
C 12
H62
C12 is no current codes. H62 is a historical. Which module was testing when the H62 came up? It displays it through each test.
Old Nov 10, 2005 | 09:51 AM
FD2BLK's Avatar
FD2BLK
C 12
H62
I can check the Helms when I get home but from what I can find
"CODE 62 OIL TEMPERATURE SENSOR HIGH"
Also 4 to 6 may have worked but I don't think it is correct, the correct pins are 4 to 12.
This site may help
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Nov 10, 2005 | 10:29 AM
Preacher94's Avatar
Preacher94
Sorry - I meant 4 to 12. That is correct. Don't want to confuse anyone in the future.
And thanks for the corvettebuyers.com site. Wish I had known about that a week ago.
I'll tell you - Corvette Form rules. So much good info. So many knowledgeable people.
Old Nov 10, 2005 | 11:48 AM
Red Dwarf's Avatar
Red Dwarf
Other suggestions?
It's been working for some weeks now. It's c4vettes.com
To Display DTC codes
