see if you guys can help me, my 86 L-98 when cold has no throttle response when cold, is there a temp sensor that affects the mixture that i need to replace? the only way i can explain it is on a carb. style car when a accelerator pump doesnt work.
just put a good fuel pressure gauge on it today at idle and under 2500 i have 20-25 psi when i stab it the press falls to 15- 10 psi. from what i've read here thats a problem. i've going to do the filter first and then the pump if needed
HOLLY F'N CRAP WHAT A DIFFERENCE!!!!!!! i'm a mopar guy but this car is sooo much fun to drive when it runs right. turns out the fuel pump was junk and causing all the problems. never thought the pump would be easier to change then the filter.
