Lowered rear Bolt kit???
Old Nov 10, 2005 | 01:06 AM
vetteville's Avatar
vetteville
7th Gear
Default Lowered rear Bolt kit???
Anyone know if this is a do it yourself kit?? I just received it from midamerica today with NO instructions??? No ideas ??? I do see the bolts in question that ned to be swaped??? anyone help??
Old Nov 10, 2005 | 01:19 AM
chucks88's Avatar
chucks88
Pretty straight forward swap. I believe all you need is a floor jack to place under the end of the spring to take the tension off....then swap the two bolts.
You may want to take some measurements prior to the bolt R&R so you can monitor your height adjustments.
This is the bolt you'll be swappin' out
Old Nov 10, 2005 | 02:08 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It took me maybe 1hr to do both sides but I jacked the frame and removed the rear wheel before jacking the spring tip to swap bolts.
Measure ride height at each rear mid wheel well point, measure the bolt length at each wheel and set the new bolt lengths to lower and level ride height.
Drive the car to allow the suspension to settle and check the ride height. Adjust till your are satisfied.
Soon after lowering the rear, get a 4-wheel alignment.
Old Nov 10, 2005 | 03:26 AM
vetteville's Avatar
vetteville
7th Gear
ok thx guys...so basically remove the rear wheels and wit hte longer bolts I will be letting down the rear knuck more?? what location are you guys jacking to let off the tension??? I assume you took the wheels off and let the car down on jack stands and then jacked up the spring??
Old Nov 10, 2005 | 08:44 AM
aboatguy's Avatar
aboatguy
I did not jack the car up multiple times I just put a wood block on my floor jack and lifted the spring. Then I pulled the tire for more clearance so I could to clean up the suspension while I was down there. This is a simple job and should take less than an hour. The front is more time consuming.
Old Nov 10, 2005 | 09:02 AM
chucks88's Avatar
chucks88
Old Nov 10, 2005 | 09:33 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You have to put the car on stands to remove the wheels, but you don't have to do either...ala boatguy...to lift the spring end and access the bolt.
Larry
code5coupe
Old Nov 10, 2005 | 11:40 PM
rgtkst's Avatar
rgtkst
Default Front???
ARE YOU PLANNING ON REMOVING THE FRONT BOLTS?? IF SO I NEED THEM. MINE HAVE A TEAR IN ONE OF THE BUSHINGS I SURE COULD USE THEM IF YOUR NOT
RON
Old Nov 10, 2005 | 11:53 PM
ROME's Avatar
ROME
Which bolts are longer, the stock ones or the one's with your new kit?
Old Nov 11, 2005 | 08:50 AM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
To make the car lower you use a longer bolt. About 9" should do the trick.
To Lowered rear Bolt kit???
