Have to ask...brake bias spring.
Old Nov 10, 2005 | 04:31 AM
CorvAdel's Avatar
CorvAdel
Default Have to ask...brake bias spring.
I just received it from Corv. Cent. in a nice new plastic bag with a part # and no instructions. It seems to have even spacing along the length of it, but I do not know where or how to fit it...can some one pl. advise with this..? TIA
Old Nov 10, 2005 | 04:49 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
If you have never done one I would not attempt it.
You have to tear down the master cyl to install it.
Old Nov 10, 2005 | 07:05 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Well that was real bloody nice of them! Maybe someone who's put one in recently has some instructions they could send you.
Old Nov 10, 2005 | 07:49 AM
GS0872's Avatar
GS0872
Don't feel bad. I got one a few months ago and was unable (unwilling) to put sufficient torque on the big bolt head on the end of the master cylinder to get the thing apart. The part's still in the bag, where it will probably stay on the shelf with the other Vette parts I've purchased but not installed through the years.
It all sounds good in the catalog, but it's a different story when I get around to actually putting a wrench, etc. to the car. I guess I'm just chicken.
Old Nov 10, 2005 | 08:23 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You have to undo the large nut on the front of the secondary cylinder of your m/c. There's a weak spring that comes out, then you'll need a bent pick to pull the combination valve out. Then you need circlip/snapring pliers to get the old spring out and new one in.
Old Nov 10, 2005 | 08:30 AM
Nathan Plemons's Avatar
Nathan Plemons
Hmm.. mine came with instructions. Being said though it's not that hard, I did it in about an hour, including bleeding the brakes.
Old Nov 10, 2005 | 11:24 AM
Solo2GS's Avatar
Solo2GS
St. Jude Donor '07
You are in luck as I have the DRM instructions for the install.
http://forums.corvetteforum.com/phot...cat/500/page/1
It will probably take you about an hour including bleeding the brakes at all 4 calipers.
Old Nov 10, 2005 | 08:03 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
and time well spent!!! This is a major improvement, IMHO
seeya
Old Jul 3, 2012 | 02:51 AM
yaknow's Avatar
yaknow
Just installed, took about 40 minutes, great improvement in braking, love it
To Have to ask...brake bias spring.
