smells like antifreeze
Old Nov 10, 2005 | 01:07 PM
lakerat's Avatar
lakerat
Default smells like antifreeze
Just in time for cooler weather, my windshield tends to fog up on the inside and can smell antifreeze. Should I be looking for a new heater core or what?
I cannot find any leaks.
Old Nov 10, 2005 | 01:42 PM
bogus's Avatar
bogus
is the floor damp?
Any leaks under the car?
what year?
Old Nov 10, 2005 | 01:47 PM
lakerat's Avatar
lakerat
I could not see any leaks either on the garage floor or cockpit and my level is good. If there is a leak somewhere, it must be pretty small.
Old Nov 10, 2005 | 02:12 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Do you have the electronic climate control? Do the windows fog when the climate control is turned off?
It could be a small leak (which as you know will only get bigger) and for now all of the leaking coolant is being vaporized so you won't find any damp spots or drips. The windshield fogging is from the warm coolant vapor hitting the cool glass and the smell of antifreeze is a dead give away that there is a leak somewhere. I might get flamed for this but you might try a good quality radiator stop leak. If the leak is very small it should do the trick without having to use so much that you clog something else in your cooling system,
Old Nov 10, 2005 | 02:16 PM
CFI-EFI's Avatar
CFI-EFI
Give it time. It WILL get bigger. There is no question. It IS the heater core.
RACE ON!!!
Old Nov 10, 2005 | 02:44 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
I treated my vette preventatively with Barr's Stop Leak. no problems so far. Add it to the radiator or upper reservoir. Comes in powder or liquid (mud) form. It may seal a small heater core leak...
Old Nov 10, 2005 | 02:48 PM
87vette's Avatar
87vette
Its your heater core. Better replace it soon before it makes a big mess inside your car.
Old Nov 10, 2005 | 02:52 PM
lakerat's Avatar
lakerat
Thanks everyone for confirming my suspicion. Since the car sits for most of the winter, maybe I can get by with sealer and put replacement on my spring list.
Old Nov 10, 2005 | 03:12 PM
Gary K's Avatar
Gary K
Heater cores are fun
No stop leak, just fix the problem
Old Nov 10, 2005 | 08:05 PM
CFI-EFI's Avatar
CFI-EFI
If you won't need the heater until spring, you can connect one heater hose to the other and totally bypass the heater core. That would eliminate the possibility of a mess.
RACE ON!!!
Old Nov 10, 2005 | 08:08 PM
rightofway's Avatar
rightofway
stop leak is just a quick fix to get you to where you can replace whats leaking.
Old Nov 10, 2005 | 08:51 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Take it to an expert
Old Nov 10, 2005 | 09:39 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Time to "get the lead out". Check Tech Tips for the "How To" on replacing the heater core. BTW Gunking up your cooling system will only cause other problems down the road. Do it right the first time.
Old Nov 10, 2005 | 11:50 PM
Movnviolation's Avatar
Movnviolation
Just finished my 89. Was waiting for a dash panel so I could close it up. Got the panel today. It is a total pain in the a##! Took me four (4) days. I had to keep walking away from it.
One member suggested a flexable nut driver. I went to sears and found a set of assorted hex and screw driver ends with a 1/4 drive & 3/8 drive ends that connect to a quick connect for a drill. I then found a flex extension approx. 8" long with quick connect. This made life a lot easier to put everything back. Wish I would have had it to take everything apart!
My core must have had a small hole because I could not see any evidence of coolant. I could smell it in the cabin however. No wet carpet!
Good luck
To smells like antifreeze
