94 LT1, AC quit, ideas?
Old Nov 11, 2005 | 01:30 PM
grayml's Avatar
grayml
Default 94 LT1, AC quit, ideas?
Hello all,
A/C quit today, when I stopped to have lunch it was working fine, get back in the car to leave and no A/C.
I didn't have low refrigerant, and I neither see nor smell a leak. When I got home and popped the hood and started checking around I found the following:
Both hoses are hot.
Pressure on the low side is about 90 PSI. so obviously the system hasn't leaked down.
Compressor isn't cycling.
As I said A/C was working great until I stopped, maybe that was just a coincidence.
Any ideas as to what steps I should do next? I know I'll end up taking it in to the dealer but if anyone has any suggestions as to what to do next I'm ready to try.
Is it dangerous to drive like this, i.e. is there any chance this much pressure on the low side will pop a hose?
Old Nov 12, 2005 | 08:52 AM
96CERon's Avatar
96CERon
Default Lost my AC clutch
My AC quite working one day but you could see that the AC clutch had fired itself--got new part at the dealer $350 and replaced it--OK then. It was easy to replace. If clutch isn't coming on first check your fuses for the clutch then make sure you have voltage at the clutch.
Old Nov 13, 2005 | 08:03 AM
grayml's Avatar
grayml
Turned out to be my clutch as well, it wasn't fried, just worn out.
Old Nov 13, 2005 | 08:58 PM
SunCr's Avatar
SunCr
If it happens again - even with a new clutch assembly - check the low pressure switch connection. There's been at least 1 other member with that problem and I had it happen on my S10. Disconnecting and reconnecting gets it working again - maybe for a couple of months. Solution is a new switch or connector.
To 94 LT1, AC quit, ideas?
