Diabolical update
Old Nov 11, 2005 | 08:52 PM
DiabolicalDave's Avatar
DiabolicalDave
Default Diabolical update
I promised I'd post when I finished. I'm all done except for the dyno tuning. So, I don't have numbers yet. But I do have plenty of pic's:
http://diabolicalperformance.com/Dia...Vette2005.html
Old Nov 11, 2005 | 08:59 PM
bogus's Avatar
bogus
uber cool!
Old Nov 11, 2005 | 09:17 PM
LD85's Avatar
LD85
Hi Dave,,, very nice work, congrats
Old Nov 11, 2005 | 09:22 PM
hngacurv's Avatar
hngacurv
Old Nov 11, 2005 | 09:44 PM
dock351's Avatar
dock351
St. Jude Donor '06
Hi Dave:
Looks like a lot of great work well done. I roamed around your site for quite awhile, there is a lot of good info there.
Old Nov 11, 2005 | 09:51 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Dave looks good. I had the same vacuum pump, but was trying to make it work off the crank....did not think of putting it up there and eventually sent it back, since I did not have the time to mess with trying to make it work....got me thinking again now....
550rwhp is going to be pretty stout to achieve with a low compression 427CI motor, that would be 660 motor hp assuming 20% through the drivetrain...
These motors barely make that much with MUCH higher compression and more cubes...http://www.shafiroff.com/434_sportsengine.asp
Hope you make it to your goals though, I know you have been working hard on it.
Are you going to run it at the track at all? Keep us posted with that you come up with....
Old Nov 11, 2005 | 10:17 PM
DiabolicalDave
Yup. When I said I should make 550hp, I meant at the flywheel. If I were talking about rear-wheel, I'd say 550RWHP. Yea, 550RWHP would be awesome. I think I'd probably have to resort to some kind of power adder to get there; nitrous or blower or turbo or rocket science or whatever.
Hey, that reminds me... This is risking highjacking my own thread, but I just posted a link on the website to a magazine article about the guy who builds the engines I sell (and he built the engine in my Vette). Jeff Dickey is his name. Here's the link:
http://moparmusclemagazine.com/techa...0602_dyno_web/
He won this competition, which is huge bragging rights for him. I'm proud of him.
EDIT: Actually, after reading the article more closely, I'm not sure he won. Jeff came back saying he'd won. He made the most hp. But, reading the article they say they factor in cost and idle vacuum. So, I guess the jury is still out (unless Jeff already knows he won the combined total).
Old Nov 12, 2005 | 09:34 AM
-=Jeff=-'s Avatar
-=Jeff=-
Dave,
I was lookign at your clutch set-up
What flywheel, disc and Pressure plate did you use?
Old Nov 12, 2005 | 11:25 AM
DiabolicalDave
Originally Posted by -=Jeff=-
Dave, I was looking at your clutch set-up What flywheel, disc and Pressure plate did you use?
From Clutch Masters, in Rialto, CA: Part No. MU1483HDR-CBR was $225
That's the pressure plate. It's rated at 1000hp
From Doug Herbert Performance, in West Palm Beach, FL: Mr. Gasket Part No. 10-330 was $219.99 That was the SFI flywheel.
From JD Engine & Machine, in Columbia, MO: Hayes PN 40-121 was $102.62 That was the clutch.
Old Nov 12, 2005 | 04:32 PM
LD85's Avatar
LD85
Dave did you have spacing issues or stack up issues with the McLeod TOB # 1345?
I am going to pull my Centerforce DF II Single mass setup out next weekend and I want to go back to the McLeod TOB with a push type clutch.
Old Nov 12, 2005 | 05:34 PM
-=Jeff=-'s Avatar
-=Jeff=-
Thanks Dave,
NExt question, how does the stack height compare the OE set-up?
I have a nice Fidanza Single MAss flywheel, if I could convert to a push type with a Hydraulic TO bearing that would be perfect.
Is the flywheel you are using the same thickness as the old Dual mass?
Old Nov 12, 2005 | 07:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
Dave, your exhaust system is simply gorgeous!
Old Nov 12, 2005 | 09:39 PM
pipe's Avatar
pipe
Cool lookin motor Is the Mini Ram powder coated or just painted? Pipe
Old Nov 15, 2005 | 10:35 PM
DiabolicalDave
Powdercoated - so is the "custom" waterneck we made to fit with the crankcase evac
DiabolicalDave
Thanks man.
Old Nov 15, 2005 | 10:36 PM
DiabolicalDave
Thanks Dave,
I went to a "conventional" flywheel and clutch setup.
Old Nov 15, 2005 | 10:38 PM
DiabolicalDave
Larry,
It's been awhile, but the way I remember it, the McLeod comes with some pretty specific instructions on measuring your clearances. My stuff just happened to fall within the allowed limits. "I'd rather be lucky than have a license to steal"
To Diabolical update
Old Nov 15, 2005 | 10:41 PM
DiabolicalDave
I'm planning to be at the tuner's Monday. Wish me luck! I'll post when I get back (unless my tail's between my legs).
Old Nov 15, 2005 | 10:44 PM
DiabolicalDave
Here's a video of a little burnout:
http://diabolicalperformance.com/vid...e90videos.html
Total loss of traction. That's one reason I'm going with the big meats...
Old Nov 16, 2005 | 04:08 AM
pablocruise's Avatar
pablocruise
Just curious, why the intake change?
