Factory wheel lock nuts?
Old Nov 12, 2005 | 09:49 PM
rodj's Avatar
rodj
Default Factory wheel lock nuts?
Are the locknuts supplied on the mags all the same pattern?
My '87 had none so has not been a problem.Have now bought a '90 with original locknuts so need to source factory adapter.
I know you can remove them with a rattle gun but have no air at home and car is not roadworthy to drive to tyre shop.
Old Nov 12, 2005 | 09:53 PM
scorp508's Avatar
scorp508
Get a cheap 13/16", 1/2", 12-point socket. Tap it onto the lugnut with a hammer lightly and it will grip enough to get them off. If the lugnut is stuck in the socket when you get it off, take a 3/8" extension and you can pop the lugnut out.
Old Nov 12, 2005 | 09:59 PM
Slalom4me's Avatar
Slalom4me
You need to contact the Customer Service department at
McGard.
It will be easiest if you are able to provide them with the information
from the registration card. If not, they have an alternate method
for assisting you.
Slalom4me's Avatar
Slalom4me
My previous post assumes you are interested in retaining
the locks.
Old Nov 12, 2005 | 11:06 PM
rodj's Avatar
rodj
the locks.
Hell no , I just want to get the wheels off.Someone has already made an attempt while it was at the wreckers yard.All the nuts are gone except the lock nut which has been partially butchered.I thought in the first instance the proper key may grip was is left otherwise I will be welding somthing to the nut to get it off.
To Factory wheel lock nuts?
