Purge/Evap canister delete!! Help...
Old Nov 13, 2005 | 01:25 AM
kopbet89c4's Avatar
kopbet89c4
Default Purge/Evap canister delete!! Help...
Seems like I have suddenly sprung a vacuum leak around there somewhere, again causing driveability issues. I can hear it hissing around that area when the engine is running. Lots of old nasty rubber vac hoses everywhere. Found a leak in the cruise control so I in turn took that out as well and sealed the T-fitting. Is it possible to just get rid of this big evap/canister purge thing once and for all? Has anyone here done this? Does anyone have a complete diagram of the vacuum lines of an 89? I don't see complete mapping chart of all vacuum lines in my $200 Helms book... That faster I find this hissing vacuum leak, the better I will feel. TIA.
Old Nov 13, 2005 | 03:05 AM
RatC4's Avatar
RatC4
I think the emissions label under the hood over there on the side of the radiator has a vacuum diagram.
Old Nov 13, 2005 | 11:27 AM
kopbet89c4's Avatar
kopbet89c4
It all faded and some peeled off. Any other sources?
Old Nov 13, 2005 | 12:37 PM
kopbet89c4's Avatar
kopbet89c4
Any drawbacks to eliminating this equipment?
Old Nov 13, 2005 | 06:22 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
This system recovers gas fumes from the tank. It's a very efficient and effective system, If you remove it a vented fuel cap is needed to keep the tank from pressurizing(sometimes) and when this is done the fumes will escape and stink up your garage. Since the tank is above the exhaust pumping that extra heat into the tank, causing more evaporation, It doesn't make sens to remove it.
Old Nov 13, 2005 | 06:50 PM
kopbet89c4's Avatar
kopbet89c4
http://forums.corvetteforum.com/show....php?t=1233480
Looks like this solved my idle problem for good. Nevermind...
To Purge/Evap canister delete!! Help...
