L98 Brake Question
Old Nov 13, 2005 | 10:44 AM
geezel's Avatar
geezel
Default L98 Brake Question
Just replaced the brake master cylinder on my 86. Bench bled the MC before installation and bled the snot out of the brakes after. Now I have absolutly no brake pedal with the engine running. I've got a pedal with the engine off. What's up with that? Does bleeding with the rear of the car on jacks, the front on the ground affect anything?
Old Nov 13, 2005 | 10:49 AM
jsinga's Avatar
jsinga
I think air is still in it.
Try bleeding the MC at the lines. Crack while pedal going down close line then let up.
Maybe someone has a good reason why you get a hard pedal without boost.
JS
Old Nov 13, 2005 | 02:57 PM
geezel's Avatar
geezel
All is well now... Just some air in the lines.
To L98 Brake Question
