85 starter interrupt switch
Old Nov 16, 2005 | 11:16 AM
morodder's Avatar
morodder
Default 85 starter interrupt switch
where is the location to starter interupt switch. not gear selector switch. or is it the same. thanks
Old Nov 16, 2005 | 01:34 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Tranny?
Old Nov 16, 2005 | 01:50 PM
86PACER's Avatar
86PACER
There's a Starter Interupt Relay. It's behind the warning light display.
Old Nov 16, 2005 | 05:03 PM
Muffin's Avatar
Muffin
My Helms shows the starter interupt relay to be activated by VATS. There is a starter interupt on the gear selector switch that prevents a start in other than Park or Neutral. Is that what you are looking for?
Old Nov 16, 2005 | 05:05 PM
85 500 horse's Avatar
85 500 horse
There's no VATS in the 85. It started in 86.
Old Nov 16, 2005 | 06:24 PM
86PACER's Avatar
86PACER
I thought there was. Guess I'm wrong.
Old Nov 16, 2005 | 07:58 PM
JAKE's Avatar
JAKE
If you're referring to the neutral safety switch, mine's under the shifter console cover.
Kind of a pain to get to since a dash panel has to be removed, then the console cover and shifter ****.
Jake
Old Nov 17, 2005 | 12:18 AM
morodder's Avatar
morodder
i was looking for the interrupt switch. which relay behind the warning light.. thank guys
Old Nov 17, 2005 | 12:23 AM
86PACER's Avatar
86PACER
Well it's been said your 85 does not have VATS. It would be the relay in the center that is mounted sideways if it did.
Old Nov 17, 2005 | 12:47 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
VATS refers to the chipped key starting in 86.
The starter interrupt relay is on all c4s and activated by the theft deterent module.
On the 85, it's behind the DIC, it's mounted sideways with 2 screws. The other sideways one to the left of it is the door lock relay.
Old Nov 17, 2005 | 08:48 AM
Muffin's Avatar
Muffin
85 has an early version of VATS. It is called Theft Deterrent System.
To 85 starter interrupt switch
