Dyno Run - Post Mods - Confused??
Old Nov 21, 2005 | 09:27 AM
Slalom4me's Avatar
Slalom4me
Originally Posted by hippy
Don't listen to the bull about the Mini losing SOOOO much low end tq,
it isn't a problem, you just need to change a few other things to take
advantage of that intake.
I know what you are saying about torque and agree that while it is fun,
there are lots of torque-challenged vehicles that run strong numbers
I recall that you've gone into some detail in past posts about the
complementary changes necessary to get the MRII to work well for
you. Given the current ineffectual state of the Search feature, could
you post back here with the highlights or perhaps links to the info
you've posted before to give 90Indy more insight into what this path
entails.
Edit: Found one - 'My Miniram vs LTR intake comparison inside...'
I know if I was going to be turning an L98 over 6 K that I'd look at
the oil pump, valve train and ignition. If I was going to 6,500 or more
very often I'd be wondering about the rods and harmonic damper. Of
course, the 3.07 rear would get changed out.
Edit: Actually, I'd be wondering about the rods before 6,500. And so on.
Old Nov 21, 2005 | 09:45 AM
Slalom4me's Avatar
Slalom4me
BTW - the remark above about 'torque-challenged' cars refers to
ones like the Honda S2000, not an MRII-equipped 'Vette. I acknowledge
that there will still be decided torque available for the 'Vette.
Also, what is your opinion about the MRII vs the SR in an application
where redline is held to 6,000 - in other words, where the owner
chooses not to make the changes necessary to support higher RPM
operation.
Old Nov 21, 2005 | 10:01 AM
bigcityvette's Avatar
bigcityvette
Originally Posted by 90Indy
CAM: Comp Cams - valve lift .464, duration @ .050 intake 222 exh 226, lobe separation 114
I did not know they made hyd. roller cams with that much duration and so little lift. Seems like a flat tappet cam to me.
Old Nov 21, 2005 | 12:50 PM
90Indy's Avatar
90Indy
Originally Posted by cplonner
Im feeling your pain, same mods, close to the same specs on the cam same intake and im getting the same power numbers.I talked to alvin and he said the dyno looked good. like these guys are saying maybe its the intake? let me know when you figure it out and ill do the same!
Misery loves company, welcome aboard. I guess if it turns out to be the intake, it could have been worse. It's just that it hurts not only the pocketbook but the desire to do it over again. But time has a way of healing all things so I am sure I'll be up to the task shortly. I just need some more time to grieve.
I'll be sure to let you know what I decide to do and how things come out.
90Indy
Old Nov 21, 2005 | 01:10 PM
Slalom4me's Avatar
Slalom4me
Just to leave you with a few thoughts about intakes.
A stock Holley Stealth Ram does not fit under the C4 hood. Modified
plenums were tried but don't appear to have panned out. One
exception - still under development - is JoBy's modification. He is
dropping the plenum down over the runners with the intent of welding
the two together.
The Toledo Pro / Melrose hood or the Greenwood / Mold Kraft scoop
appear to provide enough clearance to accomodate a stock HSR.
Several members have the Toledo / Melrose hoods and speak highly of
them.
Old Nov 21, 2005 | 01:17 PM
hippy's Avatar
hippy
entails.
Can I just give an update here.
When I first put the intake on I did think that it was soft on low end. Turns out one of my 3000 mile Bosch plugs was garbage. This car will still burn em loose when you get on it. If you put a stall in it it gets out of the area that it is lower on power that it really isn't an issue, and a gear will get you out even faster.
I still believe that the car needs to have a gear to pull in the 5000rpm and up range in 3 gear to take advantage of the intake. That is where I was seeing a loss between the 1/8 and 1/4 mile.
I also now believe that my current exhaust setup is deficient for what I have. I was going to get that redone this year but it snowed out and they salted the roads so the car is now sleeping til March.
If you have a stock shorty like me I'd let the cam dictate where you want to shift at. I know the intake is good to 7 grand but you don't have to stick a cam in that is good that high too. My 219 was making power at 6200 yet but that's where I shut it down on the dyno. I don't want to make a bunch of little pieces out of it. I am pretty confident when I get my exhaust done on the car I will see 15-20 hp.
So to condense it, put a mini on, put a gear (3.55-3.73)and stall (26-28, a good one) in it and if you chose your other engine parts correctly you will have around a 440chp 350 SBC that is fun to drive on the streets and not a bitch to work on (read SR.)
Old Nov 21, 2005 | 02:33 PM
cplonner's Avatar
cplonner
yeah my hyd. roller cam is .474 lift and dur is intake 210 exh 214. longer duration = more power? is that correct?
Old Nov 21, 2005 | 04:01 PM
lead foot 85 vet's Avatar
lead foot 85 vet
don't miss the main point gentlemen........he's building this for a blown motor.....the blower to come this winter......blown motors don't care as much about duration, lift and intake, your forcing the air in there. if anything a longer exhast duration.
