EMERGENCY POST!!! Please Help...
Old Nov 20, 2005 | 06:36 PM
mpcorvette's Avatar
mpcorvette
Default EMERGENCY POST!!! Please Help...
I'm home on leave in St. Louis and need to get back to Oklahoma ASAP, have a family emergency. Today while changing the PS high pressure hose on my 90 coupe I decided to give her a bath. I covered the ECM and sprayed her down with de-greaser. I then gently hosed the engine compartment down with a garden hose. After doing that I went to go to the store and got about a block away and found out that I had very little brakes. Is this a coincidence? The peddle is abnormally firm, brakes are 30 days old front and back. I have to stand on the peddle to get it to stop, VERY HARD. I checked the vacuum line to the power booster and it is ok. Any ideas? As it is right now it is too dangerous to drive one block let alone cross country. Please help!!!
Old Nov 20, 2005 | 06:43 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If your vacuum hose is hooked up, it sounds like an inopportune time for a booster failure. I'd locate a booster from a parts store asap if they're not already closed.
You can still drive it, but you'll have only about 60% of your braking ability, so be careful, don't need another family emergency.
Old Nov 20, 2005 | 06:47 PM
bogus's Avatar
bogus
I am wondering if when the powersteering fluid flew everywhere, it didn't land on something it shouldn't have... and ate stuff.
That's my concern. Soak the motor with simple green and hose accordingly.
Old Nov 20, 2005 | 06:54 PM
rightofway's Avatar
rightofway
could water have found its way into something it shouldn't have
Old Nov 20, 2005 | 07:01 PM
rssshen vette's Avatar
rssshen vette
Sounds like you definitely have a problem with your brake booster. Check your vacum to the bosster. If you have vacum then the booster need to be replaced. IF no vacum then check your vacum lines.
rssshen vette
101st Airborne
"Airassault"
Old Nov 20, 2005 | 07:03 PM
mpcorvette's Avatar
mpcorvette
Thanks guys, I called Advanced Auto Parts and they want $100 and of course it has to be ordered but will be there by tommorrow morning. I was thinking about the whole water issue too but I just cant see where and what it could possibly effect, the 90 brake system seems to be pretty straight forward. Any other thoughts would be appreciated, I am just a little worried about throwing parts at it and still be in the same boat. By the way, what is the little wire that runs to the side of the master cylinder???
Old Nov 20, 2005 | 07:08 PM
CentralCoaster
It's a warning switch in case either brake circuit loses presssure. Unhooking that won't cause the brakes to not work.
Old Nov 20, 2005 | 07:09 PM
mpcorvette's Avatar
mpcorvette
rssshen vette
101st Airborne
"Airassault"
MP
The Force of Choice
Old Nov 20, 2005 | 07:10 PM
George Dickel's Avatar
George Dickel
Did you by any chance get any power steering oil onto the brake rotors or degreaser/oil/water mixture splashed on them when you hosed the engine off? It doesn't take much oil on the rotors to really degrade braking capability. If you did, use some aerosol brake cleaner liberally on the rotors and pads and see if that doesn't help. Make sure it is brake cleaner not some other type of cleaner.
By the way, MP with Company A 95th MP Bn, Mannheim, Germany. 1971 - 1974. 411th MP Company, III Corps, Fort Hood, TX. 1974 - 1977.
Old Nov 20, 2005 | 07:42 PM
rssshen vette
that little wire is the sensor for low brake fluid warning
Old Nov 20, 2005 | 07:53 PM
MtlSphere's Avatar
MtlSphere
Originally Posted by George Dickel
Did you by any chance get any power steering oil onto the brake rotors or degreaser/oil/water mixture splashed on them when you hosed the engine off? It doesn't take much oil on the rotors to really degrade braking capability. If you did, use some aerosol brake cleaner liberally on the rotors and pads and see if that doesn't help. Make sure it is brake cleaner not some other type of cleaner...
If it was working fine before the soaking then don't out-think yourself. You most likely got water and degreaser on the rotors. Drive slowly around the block riding/dragging the brakes. A little bit of fluid can adversely affect brake performance but it can usually be burned off very quickly.
Hope you make it back home to the Great State of Oklahoma soon and find all is well here!
Old Nov 20, 2005 | 08:20 PM
DanZ51's Avatar
DanZ51
That's my guess too; crap on the rotors. Doesn't take too much to surprise the crap out of you
Your pedal height is still the same, right?
Good luck.
323rd Maintenance Company
Devens RFTA
Old Nov 20, 2005 | 08:37 PM
mpcorvette's Avatar
mpcorvette
The pedal height seems to be the same just VERY stiff. I have drove it up and down the street a few times and got nothing out of it but some weird looks from the neighbors. I am gonna tackle the booster tommorrow in the light of day. Does anyone know how many bolts there are on the 90? My manual (Crappy Haynes) says 4 but all I see is 2 under the dash. Doesnt look to fun but gotta do it, brakes with no power assist for 600 miles on the highway is not an option for me. I like staying above ground. Thanks again for the quick replies, much appreciated...
Old Nov 20, 2005 | 10:33 PM
Fick's Avatar
Fick
If everything else fails you might replace the vacuum hoses. I had a similar problem with brakes and after replacing everything else found that a weak vacuum hose looked ok but was collapsing and closing off durring braking.
Old Nov 21, 2005 | 09:17 AM
rick lambert's Avatar
rick lambert
look closer-there are four bolts, I'm thinking booster big time, I've had the grungy brake/rotors b4, and they do burn off while driving with the brake pedal depressed (lazy mans way) but the stiffness you're feeling sounds like a bad booster or vac line to it.I think it was just coincidence
with the water.
Old Nov 21, 2005 | 11:26 AM
MtlSphere's Avatar
MtlSphere
with the water.
Well...if Rick Lambert says it's the brake booster then By God it must be the brake booster!
Couldn't possibly be water and degreaser from the soaking ...no uh-uh...gotta be a catastrophic brake booster failer at the exact moment H2o was applied.
Some of you "expert" guys floor me
No problems until he gets the thing wet...then all of a sudden...like Peter Lorre outta chute number two; The brake booster fails? Highly unlikely.
And if you're the kinda guy that takes the front end apart just to dry the pads and rotors after a wash...well call me lazy... cuz you gotta be the most industrious guy on the planet!
Old Nov 21, 2005 | 11:37 AM
cv67's Avatar
cv67
St. Jude Donor '05
That's what I was thinking...
To EMERGENCY POST!!! Please Help...
Old Nov 21, 2005 | 02:07 PM
SJW's Avatar
SJW
You've received some good advice here -- before you go to all the trouble of swapping out the booster, definitely check the front pads/rotors for contamination, and verify good vacuum to the booster.
Usually when a booster fails, it's a rupture of the diaphragm, and if this were the case, you'd likely hear a hissing noise, and/or have a poor/no idle condition.
It's not impossible that the booster has developed a problem, but I'd strongly recommend you look elsewhere first.
If the pads/rotors have become contaminated, unbolt the calipers and swing them aside, and get the rotors scrupulously clean using a true brake cleaner. Others have suggested cleaning the pads, and you could try this, but if they're contaminated, I'd recommend you just go ahead and replace them. Pads are cheap, and accidents aren't.
Be well,
SJW
Old Nov 21, 2005 | 02:58 PM
Jet-Jock's Avatar
Jet-Jock
Yeah seems awfully incidental. Try spraying the front suspension, brake assemblies down with Simple Green give it a minute and rinse. Then take it for a short drive and re-bed the brake linings. 20 medium-firm stops from 30mph (one after the other). Let them cool down a little and then drive it again and see if they don't improve. At about stops 16-18 you should start smelling them. Of course you should have done that as well when the pads were replaced.
Old Nov 21, 2005 | 03:17 PM
mpcorvette's Avatar
mpcorvette
Thanks everyone for all of the help, you really helped me through this. Turns out it was the booster. After removal and inspection I found a huge crack in the plastic housing, it was posistioned so I couldnt see it with it still on the car. Looks like it has been working its way bigger and bigger over time, this might explain my rough idle and hard start up problem too. The whole job was not overly tough, just a pain in the butt, you have to be a circus contortionist to get to the damn nuts under the dash. Anyway, shes all buttoned up now and I'm hitting the road, thanks again guys for all the help, another satisfied customer.
