oil temp gauge
Old Nov 20, 2005 | 10:10 PM
takovr's Avatar
takovr
Default oil temp gauge
On my 86 vette my oil temp read-out gauge reads low all the time my oil pressure reads fine though. Were is the oil temp gauge sending unit located and is it hard to change?
Old Nov 20, 2005 | 10:33 PM
nonetooclose's Avatar
nonetooclose
First, it is not really an oil temp sensor since I believe it simply measures the coolant temp in the cylinder heads.
On my 85 it is on the driver's side of the engine just below the head towards the front of the engine (one 1/4" blade connector going to it)
Mine is always heading high, and I think it may be related to the TPIS headers I have on the car.
Richard
Old Nov 20, 2005 | 10:34 PM
SunCr's Avatar
SunCr
Sender resistance increases with pressure so a grounded circuit (no resistance) will give you LO at all times. Sender is to the left of the distributor. You want the tan wire which goes to A2 in the Bulk Head Connector behind the Battery and from there, to Pin C1 at the cluster. Check it for a short to ground. Or get a 90 ohm resistor at Radio Shack at place one end on the Tan Wire and the other to Ground. If the Cluster shows 80 PSI the wiring and Cluster are good.
Old Nov 20, 2005 | 11:17 PM
RWDsmoke's Avatar
RWDsmoke
My oil temperature sensor is located just above the oil filter and reads low if the wire is unplugged.
Old Nov 20, 2005 | 11:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Old Nov 21, 2005 | 12:54 AM
Trog's Avatar
Trog
If your sending unit needs to be replaced, let me know. I have a new one that I ordered in error (mine takes a 3 wire connector, earlier years take the one wire) and of course electrical items can't be returned. I'm on vacation though till the middle of next week, after that if you want it, you can have it for $5.00 to cover shipping. I'll post the part number when get home.
Old Nov 21, 2005 | 06:20 AM
takovr's Avatar
takovr
Default thx
thank you all for the help, I will check it out and see what needs to be replaced...
Old Nov 21, 2005 | 11:54 AM
SunCr's Avatar
SunCr
Oops! My mistake - thought you meant the pressure sender. Temp works the opposite. Higher the temp, lower the resistance. Green/White to ground at the sender should give you max temp. Disconnected or open LO.
Old Nov 22, 2005 | 11:17 AM
woody1243's Avatar
woody1243
Trog, if takovr won't take you up on the temp sensor I will. Let me know. If he takes it and you have the part number that will help too.
Thanks,
Woody
To oil temp gauge
