93 scanner problems
Old Nov 21, 2005 | 07:26 AM
kalister1's Avatar
kalister1
Default 93 scanner problems
I downloaded several articles/posts on reading data from the ALDL. I have a 93 Ruby coupe, Automatic Transmission. The information I have says to connect to pins A & E on the ALDL, my problem is I do not have a pin in socket E. I also looked into WinDL, but it does not list an ECM for a 93 LT1. What are you using on a 93 Auto.
Old Nov 22, 2005 | 02:20 AM
Morley's Avatar
Morley
Try pin M instead of E. Pin E was used in the earlier TPI's. Then they wired E & M together and then finally they dropped pin E all together.
