Bose reciever box removal
Old Nov 21, 2005 | 11:34 AM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
Default Bose reciever box removal
On a '90, do I really need to pull the whole upper dash pad to get the reciever box out?
Old Nov 21, 2005 | 01:32 PM
Grace91's Avatar
Grace91
I went in from the bottom by removing the lower kick panel. It was a PITA but it eventually came out and went back in.
There are some good instructions at this site. They also rebuilt my unit and amps.
http://www.carstereohelp.com/strcorvette.htm
Good luck!
Old Nov 21, 2005 | 02:02 PM
CMYC4's Avatar
CMYC4
The "CDM" box is up there! its a little silver box (pass. side), I'd put a new or GOOD rebuilt one back. Just be careful w/ a used one, You dont wanna have to go up there again!
Old Nov 21, 2005 | 04:42 PM
Vette73's Avatar
Vette73
LS/MFT
I knew there had to be a "trick" and that if there was, the guys on the Forum would know it
I pulled the lower kick panel and fuse box cover off, but the instructions in the GM Service Manual started with "remove upper dash pad as indicated previously in these instructions". I hate when simple instructions begin with "remove both frame rails".
Thanks, I'll give this a try over the holiday.
Old Nov 21, 2005 | 06:26 PM
-=Jeff=-'s Avatar
-=Jeff=-
yeah I did this on a 90 vert.. I removed the lower hush pad and persuaded the unit out with out pulling the dash pad.
To Bose reciever box removal
