Probably a stupid question, but...
Old Nov 21, 2005 | 02:19 PM
87l98vert's Avatar
87l98vert
Navigator
Default Probably a stupid question, but...
Hi. I'm relatively new to forum (read a lot but don't post much).
I have an 87, A4, 2.73 rear, cat back exhhaust.
I like the way my car rides(handling/acceleration).
I like the low/mid range torque.
My question is, should I be able to spin the tires just by "flooring it"?
Of course it will smoke em from a power brake, but when I just nail it from a dead stop...not even a chirp.
I know my car is stock but I was just wondering if it is lacking performance somewhere that I can check into.
I see that so many forum members have trouble "hooking up" at the track, and sometimes go with drag tires for better traction.
I didn't want this question to sound too stupid...but I was just curious.
Thanx
Old Nov 21, 2005 | 02:31 PM
CFI-EFI's Avatar
CFI-EFI
Too many variables. There is no firm answer. Take it to the track and compare your results with all the reading you have done here on the forum.
RACE ON!!!
Old Nov 21, 2005 | 02:46 PM
jodyeastman's Avatar
jodyeastman
I would say yes. I do not have an 87 but I would think any corvette should be able to burn rubber from a stand still. Mine could before the mods, that I know.
Old Nov 21, 2005 | 03:02 PM
dock351's Avatar
dock351
St. Jude Donor '06
My vette, a '90 L98 with similar characteristics to yours, it would not burn rubber much. if it did, it was a li'l chirp on asphalt on a hot day.
Old Nov 21, 2005 | 03:03 PM
bogus's Avatar
bogus
there is torque... but there is also a lot of tire...
Old Nov 21, 2005 | 03:17 PM
JohnyH's Avatar
JohnyH
BUT I have an 88, auto, vert and if I stomp on it from a dead stop it don't go nowhere and that's with 315's on the back and no brake peadal, but lots of smoke from the tires! Way to much fun!
Old Nov 21, 2005 | 04:00 PM
87 rag's Avatar
87 rag
My 87 will spin the tires when I stomp on it but there was a time when it would not.
Turned out my timing was off by quite a bit. I think a mechanic set it without disconnecting the est wire.
I bought a timing light (and many other tools) and don't let anyone else tinker with it unless it's something I just can't do myself.
I have the 3.07 gears, this may make a difference as well.
Depending on the catback you have you should be running a little more power than stock and your tires should spin.
Old Nov 21, 2005 | 05:40 PM
Ramanstud's Avatar
Ramanstud
the gears are hurting your ability to spin the tires.
numerically small gears combined with a low-stall converter means the engine starts putting it's power to the ground at around 1500 rpm or so (stock) - even with the corvette's natural torque advantage, this is not good for smoking tires given the gearing and stall.
I'll bet you're in the ballpark of normal power output, as my 84 with 3.07 gears and 300+ ft-lbs of torque would not readily spin the wheels. Now add in an aftermarket converter and other goodies, and it's not so much a problem anymore... lol.
In a way, no spin is a good thing - you'll accelerate somewhat more quickly.
Old Nov 21, 2005 | 06:20 PM
CFI-EFI's Avatar
CFI-EFI
RACE ON!!!
See what I mean???
RACE ON!!!
Old Nov 21, 2005 | 07:03 PM
LT4BUD's Avatar
LT4BUD
Too many variables. ...
RACE ON!!!
When my '89 L98 with 3.07 perforance axle was new I could usually go WOT with little or no tire spin....maybe a chirp....even on wet pavement
6 years later......with the original gaterback tires.......still a bone, and I mean bone stock engine the car was almost scarry to drive...the tires would spin so easily.....and tread depth they were not anywhere near bald.......but the rubber was obviously old and hard.....
So I agree too many variables.......but the biggy is tires & the surface conditions
So the fact you don't spin the tires is probably an indication of good tire traction.......rather than poor engine performance, but??????
Old Nov 21, 2005 | 07:39 PM
cmontel727's Avatar
cmontel727
I have an 87 with the same rear ratio as yours and I can barely get the tires to come loose on new tires. With the old worn gatorbacks she would smoke like a monster from a stand still. Probally why I needed to buy new tires Hope this helps
Old Nov 21, 2005 | 07:58 PM
Lichen's Avatar
Lichen
This was exactly my situation, with my 2.59's and hard Dunlops, my car would spin sideways. Now, with 3.54's, high stall converter and sticky GSD3's, they just spin a little bit. Tires make a big difference.
Old Nov 23, 2005 | 11:25 PM
Brimis's Avatar
Brimis
I agree, too many variables. I have Kuhmo's on my stock 84 and can smoke the tires if I tap the throttle, but then it is a hard tire and does not hook up.
Old Nov 24, 2005 | 12:20 AM
cv67's Avatar
cv67
St. Jude Donor '05
I don't want mine to spin from a standstill, I want it to hook!
Old Nov 24, 2005 | 12:46 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Based on my 86 coupe and what you posted Id bet the axle ratio combined with the Auto is the reason
Put in a higher stall and a rear gear and I bet there would be a huge difference
Then you might try.....
Old Nov 24, 2005 | 03:28 AM
TIMSPEED's Avatar
TIMSPEED
My question is, should I be able to spin the tires just by "flooring it"? Of course it will smoke em from a power brake, but when I just nail it from a dead stop...not even a chirp.
Couple of things working NEGATIVELY against you here...
1.) Stock Torque Converter = 1400rpm
2.) Stock Gear Ratio = 2.73's
If you go from DEAD idle to 100% WOT instantly, it SHOULD be able to spin the tires, not like go-up-in-smoke spin, but decently give you the "fishtail" feel. In my 87, when it was 100% stock, it would only give me a slight spin from dead idle, and I have 3.07 gears! Don't worry about it man! It really comes down to the torque converter/gears/tires...change those three variables and you'll get spin...not that that's so much a GOOD thing, but it sure is fun
Old Nov 24, 2005 | 10:14 AM
Biff Buyer's Avatar
Biff Buyer
i have a stock 85 and i can fishtail fairly easy when i just stomp on it.
Old Nov 24, 2005 | 10:53 AM
Nico's Avatar
Nico
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
I have an 84 crossfire stock and it does spin quite a lot whwn I put it to the metal. Are there differecces between models?
Old Nov 24, 2005 | 11:29 AM
CFI-EFI's Avatar
CFI-EFI
RACE ON!!!
See what I mean???
RACE ON!!!
My car hooks up in the burn out box. But what the hey, it's only a stock 13 second Crossfire.
RACE ON!!!
To Probably a stupid question, but...
