horrible squeaking (not interior rattle/squeak)
Old Nov 21, 2005 | 05:21 PM
rightofway's Avatar
rightofway
Default horrible squeaking (not interior rattle/squeak)
i have a sort of squeaking noise coming from the left rear wheel area it is almost always there and sometimes actually sounds like a grinding it also speeds up with the car
what and how should i check it out?
Old Nov 21, 2005 | 05:25 PM
Toy90's Avatar
Toy90
Pull the wheel off and check the wheel bearing. It could also be that your brake pad is worn all the way down and you have metal grinding metal. If you have rusty dust or brake pad dust on your wheel it's probably the brakes.
Old Nov 21, 2005 | 05:27 PM
rightofway's Avatar
rightofway
the brakes are brand spankin new
how do i check the bearing?
it won't just let my wheel go will it?
Old Nov 21, 2005 | 05:56 PM
vader86's Avatar
vader86
Sounds like a rear wheel bearing. Jack up the rear of the car and grab the wheel at 12-6, if it moves, something is up with that bearing.
If its very bad, yes the wheel can fly off. I've seen it happen once.
I prefer AC Delco for bearings, but they run at about $225 each. Cheaper off-brands will come in around $150ish.
Old Nov 21, 2005 | 05:58 PM
geezel's Avatar
geezel
When a u-joint on my half shaft went out it sounded just as you describe.
Old Nov 21, 2005 | 07:00 PM
JackDidley's Avatar
JackDidley
Me too.
Old Nov 22, 2005 | 05:56 PM
rightofway's Avatar
rightofway
how do i tell if it's a u joint?
Old Nov 23, 2005 | 04:31 AM
86PACER's Avatar
86PACER
Pour some motor oil into an empty spray bottle. Lay on your back and squirt some motor oil onto the halfshaft u-joints on the side where the noise seems to come from. Or spray all 4 u-joints if you want. Drive the car. If the noise went away, it's the u-joints.
Old Nov 23, 2005 | 09:49 AM
vader86's Avatar
vader86
Generally they tend to go at the same time, bearings and joints. One wearing will wear the other.
If there is any clunking or banging going into gear, manual or auto, that would indicate a joint failure.
For that you want Spicer Cold Forged U-joints with NO zerk fitting, dont buy any other brand.
Old Nov 23, 2005 | 06:36 PM
rightofway's Avatar
rightofway
thanks a bunch and, one last question, wheres a good source for the joint and which ones fit?
Old Nov 23, 2005 | 09:16 PM
vader86's Avatar
vader86
Tom's Differentials, they'll have what you need, just tell them what I told you and the application.
To horrible squeaking (not interior rattle/squeak)
