Questions on e-Tec Heads - Any problems?
Old Nov 21, 2005 | 11:32 PM
ramiles's Avatar
ramiles
Default Questions on e-Tec Heads - Any problems?
Looking to upgrade my '86 L98 with e-Tec heads - notice the plugs are different - any problems with headers or exhaust - if there are problems any good solutions?
Also any reason why these wouldn't be good heads for a street only motor focused on torque (the 170cc version)?
Old Nov 21, 2005 | 11:43 PM
Curveit's Avatar
Curveit
If this is the "Vortec" type head, it will require a new intake manifold base.
Old Nov 22, 2005 | 12:27 AM
bacardioil's Avatar
bacardioil
talk to harold at port pros in TX. tell him gene told you to call him. he will do your heads up for you. harold worked for some of the biggest name engine builders in the country. portpros.com
Old Nov 22, 2005 | 01:09 AM
ZD1's Avatar
ZD1
I have the Fast burns. What turned me off of the edelbrocks was the spark plug boot clearance with headers. For the $ just go with the AFR 180/195 l98 replacement heads.
I you have the aluminum heads, i'd put the dollars into the intake first.
Old Nov 22, 2005 | 08:31 AM
cplonner's Avatar
cplonner
Do know what their max cam lift is? Im asking because i have the standard vortec heads and my max lift is only .474 which is not a very high lift from stock, so if you want a bigger cam look into that before you buy the heads. I think the e-techs where set up for somthing like .550 but im not sure.
To Questions on e-Tec Heads - Any problems?
