C-Beam caulk kit
Old Nov 22, 2005 | 10:04 AM
vettef6's Avatar
vettef6
Default C-Beam caulk kit
The caulk kit for the C-beam has been discontinued through GM. What do you fellows use instead.
Just plain old silicon??
Old Nov 22, 2005 | 11:34 AM
MarkBychowski's Avatar
MarkBychowski
I just put it back together clean. I've heard of others using liquid nails. IMO Silocone is too soft to do any good.
Old Nov 22, 2005 | 01:05 PM
89corvetteken's Avatar
89corvetteken
I too put mine back together clean.The calk is to prevent corosion so
unless you drive in a salty area it is a non issue.
I do recamend the Beam plates which I did use.
Old Nov 22, 2005 | 01:37 PM
all4c4lt4's Avatar
all4c4lt4
That's what I did.
Old Nov 22, 2005 | 02:18 PM
Atok's Avatar
Atok
I didn't re-apply the caulk either. No issues for the past 3 years.
Old Nov 22, 2005 | 04:55 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
3m 5200 Marine adhesive
Old Nov 22, 2005 | 11:20 PM
Hotred94's Avatar
Hotred94
Liquid Nails will work.
Old Nov 23, 2005 | 12:42 AM
SouthernSon's Avatar
SouthernSon
I used liquid nails and the zip products c-beam plates. I still have a creak upon initial acceleration. I would suggest using a WHOLE LOT of liquid nails. Clean the area really well and slather it on. You may even 'open' up the beam a little so you can get a bunch on the contact points before tightening.
Old Nov 23, 2005 | 01:18 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Nothing. I don't want to put up with that crap every time I take it off.
Old Nov 23, 2005 | 04:19 AM
93 ragtop's Avatar
93 ragtop
I put mine back together with no sealer like most on here have. I wonder if anyone using liquid nails have tried to seperate it after installing? I have no experience with liquid nails on a car, but on construction jobs, that stuff holds well. After it has curied, it will split the wood before the joint will break. I cant help but wonder, what kind of problems they will have pulling the c-beam in the future.
Old Nov 23, 2005 | 05:37 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Acetone and a big standard tip screw driver.
Old Nov 23, 2005 | 05:39 PM
vettef6's Avatar
vettef6
As I see it, most of you are using the C- beam plates. Does anyone know why the upper plates look different. Why aren’t they made the same way??
Old Nov 23, 2005 | 08:37 PM
Strick's Avatar
Strick
The front beam plate has a notch cut out for clearance. The nut size is also different (if I remember right :o )
Also, some guys have used wind shield adhesive, the black stuff, which is very close to what the factory uses.
Old Nov 23, 2005 | 08:56 PM
WVZR-1's Avatar
WVZR-1
Default Sealant
The original GM part#'d adhesive through several part# changes is now the current part# for the urethane windshield sealant/adhesive. Liquid nails is interesting as is the 3m 5200 marine stuff. Decisions decisions!!!
Old Nov 23, 2005 | 09:57 PM
aboatguy's Avatar
aboatguy
That is what I used. I don't believe that it has any mechanical purpose except to keep moisture and crap from between the c-beam and the diff. I would have skipped it however, I drive in rain and crap!
Happy Thanksgiving everybody!!!!
Mike
Old Nov 24, 2005 | 06:13 AM
vettef6's Avatar
vettef6
This might be true but doesn’t have anything to do with the upper plates; they look quite different. The one in the front just has a washer on top of the nuts so they won’t fall out. The one in the back has twice as much bracing welded on the plate. There must be a reason for doing this!!
Or is it just so, that no one gets the notion of reproducing these plates themselves???
To C-Beam caulk kit
