86 Brakes
You can sorta feel if the adjustment is too far when you put the mc back over it. I tried measuring it out, but the mc doesn't mount flush against the face of the booster.
I don't know if all the different power brake boosters on the market have adjustable rods but if yours doesn't, you can always add metal shims to take up the clearance.
Jake
Jake
I shimmed mine last year when I had to replace my booster and had the same pedal travel problem.
Jake
resolve your problem, take it for an extended drive, get out and physicaly feel each wheel for heat.A friend adjusted the rod on an old Ford van I had and took it to far-if you go to far the brakes can actually have constant pressure on them-which causes them to over heat, and also causes the pads undue wear.
Jake
Are you putting nickels inside the m/c against the piston or something? How did you add length to the pushrod or add length to the piston without causing more harm then good?
Small, flat metal discs did the trick for me. Even small metal washers can be used.
I shimmed mine well over a year ago and I've driven all over the country without a problem since then. Many thousands of miles: First from Texas to Indy for Super Chevy in 2004, then to Chicago, then to Mass, down to South Carolina, back to Texas, then to Denver, then back to Texas and now I'm back in Chicago again.
If I was to experience any "harm" it surely would have reared its ugly head by now.
Jake
removing the booster-IF it turns out to be the booster-and because of your prior post, and this one-that would be MYnext move-there are metal after market boosters available for our C4s, and when I do mine-that's what I will replace it with.
I hope I'm just not reading this right.
Anybody know how suceptible to damage these booster are while fiddling wiith the push rod?
Or.. if they can 'self-adjust' themselves somehow?
All i can think of is you have the booster rod too far out, which was ok with the air in the brake lines, but after driving it and pumping the brakes a bit you forced some air out into the reservoir, and now the brakes are binding. If you had a bad booster you wouldn't be able to get lockup at any speed IMO.
When you say the pedal is getting very stiff, are you sure the brakes are close to locking up, or does it just seem that way because of the pedal force?
So let's just agree to disagree and drop it.
Jake
Take a streight edge and lay it across the plastic on the brake booster where the master cylender bolts to. Measure about 1/4 inch in from the
streight edge you have across the brake booster,to the end of the nut that is black and hold the silver part with a pair of long nose vice grips.
Turn the black nut in or out to obtain the clearence you need.
The black nut will turn hard at first, but it will losen up after you break the lock tight lose.I used a 8mm socket on the little black nut.
You have a lot of peddle travel so the nut needs to be turned counter clock wise to bring it closer to the master cylender.I used a 5/64 th allen wrench to get the distance between the black nut and a streigh edge across the two big studs sticking out of the booster,works for me.
After you adjust it drive it for atleast 5 miles,if the brakes dragg then you need to do it all over again and turn the nut in about a 1/16 at a time to get it closer.Clock wise will give you more play and counter clock wise and you will have less travel.
