Battery Question
shut off completely for a second and came back on....then about 30
seconds later it did it again. Could this be a battery problem?
If it is much lower than this, then I would be looking at the alternator
with some suspicion.
to swap out the alternator.
Disconnect the battery - the large terminal on the alt is hot.
Use ignition wrenches or something with thin enough flats to permit you
to hold the hex of the stud while you break free and loosen the nut.
If you don't, the stud turns and and breaks a connection inside the
alt. A dealership tech has performed this 'mod' for me in the past
(it was a pain having to repair what had been a perfectly good alt
before he removed it to access other stuff.)
power to the lamps and has nothing to do with the battery or alternator.
shrinkage?
shrinkage?
Good luck,
help' thread has suggestions about checking
the cluster for broken solder traces on the circuits.
When the search feature works again, I think you'll
find threads in the archives about bad cluster solder
traces, too.
I haven't seen this mentioned yet in your thread and
it is possible your symptoms are caused by a combo
of issues. (FWIW - my climate control lighting is
sensitive to weather. Cleaning the contacts worked
but the problem is back and I'll be looking at the
traces at some point.)
I'd still check for bad grounds first. If you come up
empty-handed, checking the traces for breaks is
another troubleshooting measure to apply.
