Summer Project Build (94 LT1)
Here is what I have done, It is a 1994 Auto, daily driver, will run a few passes on the 1/8th.
Hotcam
Cloyes double roller timing gear set
1.6 Crane Gold Race roller rockers
EM long tube headers (coated inside and out)
CSR electric water pump
stock LT1 aluminum heads ported & polished
Comp Cams (26915) Beehive valve springs/retainers
3 angle valve job
Cut-back valves
ATI SFI rated balancer
MSD Superconductor plug wires (red)
Upgraded to 95 timinig cover and vented optispark
EGR deleted
Air Injection deleted
Things to do-
High flow cats (I could use some advice here)
New injectors
pcmforless tune (I need to contact them yet)
I will stay with the stock exhaust at least for now.
I painted the block red with ceramic high temp paint, powdercoated the PCM case (red), throttle body (red),intake manifold (black), hermostat housing (red), water pump housing (black), alternator/ac compressor bracket (red) etc.
What kind of hp do you folks think I can expect?
I have pics of the engine and head porting to post if I can ever figure out how to do it.
Have a great Thanksgiving day, I hope you can all be with your family, as many of our soldiers, sailors, marines, and airmen will not be, let's keep them in our thoughts.
prattman
I have yet to get a good tune , but if you have a way to, get it done locally, while on the dyno (or a good data-logger)
My guess? 360-370 RWHP once you are done
Corvette Kid NC,
You asked if it is auto or 6 speed, the answer is auto.
I hope I am not displying how stupid I am, but I don't remember seeing a resonator on my 94 last January when I had to replace the transmission.
I have been wanting to post pics in my gallery on the forum, but I need to delete some to have space, then I was going to post a link for you guys.
There has been issues with the gallery due to software that the forum dudes are going to fix. As soon as that is done I will be able to get those pics posted.
About the porting, I did it myself and it was a job I would rather not do again. I ported both exhaust and intake ports, and polished them all to a mirror finish. There is some difference of opinion on smoothing out the intake ports to the degree that did, but we will have to wait and see what the Dyno shows. I hope I didn't make a mistake by doing that
I see a wide range of hp estimates, thanks to all that have replied.
prattman
Best of luck.
-Mike
Try this link for the pics of the engine/heads I have been promising.
I hope this works.
prattman
http://pg.photos.yahoo.com/ph/pw0666/album?.dir=/f160
