Cam Install question
Old Nov 25, 2005 | 02:40 AM
Epyon127's Avatar
Epyon127
Default Cam Install question
I want to install a cam over the winter and I am concerned more about degreeing it than the install. As a comparison about how much would a shop get to install and properly degree a cam?
Also can you install a cam drive it home and then get a new tune, or will it not run at all without reburning?
Old Nov 25, 2005 | 07:58 AM
Strick's Avatar
Strick
I think a better question is "How do you degree a cam?" especially with the heads still on? On a LT1/4, how do you find Top dead center?
Yes, your Vette will run until you reprogram your PCM, but not nearly as good as it should.
Old Nov 25, 2005 | 04:00 PM
Epyon127's Avatar
Epyon127
See I don't know the answer to those questions for sure. I believe I have heard of techniques with a spark plug tool that whistles or a dowel in the plug hole but I don't know anything about degreeing a cam. I was pretty sure it is beyond my knowledge. I am really interested in how much a shop would want to do it.
To Cam Install question
