Changing 85 to an 88
Old Nov 26, 2005 | 10:52 AM
printz's Avatar
printz
Default Changing 85 to an 88
I would greatly appreciate any help for the following things I need done. I have an 85 corvette with a badly damaged top and fender. I recently got a good deal for a top and bumper off an 88 corvette. How hard would they be to adapt to the 85. Also who has the best price/performance for a radiator for the 85. Thanks and take care, Printz. P.S. I am sorry if you have heard these questions before.
Old Nov 26, 2005 | 12:20 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
The top will not fit, I believe the cutoff for a top that will fit an 85 goes to early 86 style ( listed as 84 to E86 here ) beyond that, they won't work. There are actually 3 styles total from 84-96.
The bumpers and fenders from an 88 will fit fine, my front bumper and hood are from an 88, maybe 89.
I want to add this advice that would have helped me, before you buy anything that is not specifically 85, ask here if it will work (and that goes for any year). I bought the hood and the deal wasn't much of deal anymore because I had to purchase wheel housings, they are diff't from 85-88. This occurs rather often for a seemingly homogenous design for 12 years of C4. Another good example is rear glass, look the same for 12 years but the metal plate at the roof connection from 86up has holes for 3rd light, 84,85 do not. It may not be a deal if it costs 200 have the holes filled/created for your application. Just take a second to ask here, it's what we're here for and will at least reduce your wasted efforts. Good luck
Old Nov 26, 2005 | 12:30 PM
ED HEISER's Avatar
ED HEISER
Default 88 top on a 85
I know the mounting plates are different after 86E so an 88 won't fit out of the box, but does anybody know what modifications are necessary other than swapping the plates, or if it is practical
Old Nov 27, 2005 | 08:04 AM
printz's Avatar
printz
Default changing an 85 to an 88
I was told there was a kit to adapt the 85 toan 88. Is this true, and who sells it. Any help would be greatly appreciated.
Old Nov 27, 2005 | 08:10 AM
danno85's Avatar
danno85
I have an '88 top on my '85. In addition to the top, you will also need the mounting brackets that bolt to the windshield frame. These are the brackets that the top attaches to, and that also the sun visors mount in. They are very easy to change. I'm not sure if you'll need the plastic trim piece that goes below and inside the frame - I don't think that piece was different. If you can't get these parts from the person you got the top from, then search out a Corvette salvage place for them.
Dan
Old Nov 27, 2005 | 08:12 AM
eric_daniel's Avatar
eric_daniel
There is a kit to modify it, but I can't remember where I saw it. Search all the typical sites- ecklers.com, madvet.com (i think), corvette central, etc. also search ebay.
Old Nov 27, 2005 | 08:39 AM
randy814u's Avatar
randy814u
You don't need a kit, you just need these parts to match the year of the top
Old Nov 27, 2005 | 11:14 AM
danno85's Avatar
danno85
Yep, that's it
Old Nov 27, 2005 | 03:55 PM
AFogleman's Avatar
AFogleman
I did the same thing.I like the newer top.I have a 96 blue on my 86.
Old Nov 28, 2005 | 12:23 PM
nonetooclose's Avatar
nonetooclose
If you cannot buy the mounting pieces from the person who sold you the top and you do not want used pieces I believe you can purchase them from the general as well.
I have a 92 top on my 85 and it looks great!
Old Nov 28, 2005 | 01:13 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
I realllllly wish I would have known this. I played hell with the body shop trying to get a top for my car when the tree fell on it!
my 1st post (at least the part about the top anyway)
Old Nov 28, 2005 | 02:16 PM
JAKE's Avatar
JAKE
That's exactly why I always check with this Forum. Seems there's always a member that knows the answer to whatever question/problem I have or, at the very least, puts me on the right path to finding the solution.
Still can't figure how I EVER got along without this Forum!
Jake
Old Nov 28, 2005 | 04:00 PM
VtVette's Avatar
VtVette
You can usually find someone parting a car out with the proper mounts you need to fit the appropriate year top to your car. Put a wanted to buy post in the C4 parts for sale/wanted section here on the forum. Worse case few years ago I bought the mounts right from the local dealer and as I recall they were maby $20 a piece new. The trim piece would probably be pricey from the dealer, but you should have no problem finding that used either.
Brian
VTvette
To Changing 85 to an 88
