11 second combo
Old Nov 26, 2005 | 11:57 AM
rlane5's Avatar
rlane5
Default 11 second combo
Hi everyone,
I need an 11 second n/a combo, I want it to run on all MOTOR no nitrous, turbo or supercharger. It's an 86 vette and I want to be able to drive it across country if I had to.
Randy
Old Nov 26, 2005 | 12:06 PM
Corvette0096's Avatar
Corvette0096
See sig.
Old Nov 26, 2005 | 12:12 PM
rlane5's Avatar
rlane5
How hard is it to get a 350 to run 11.40?
Randy
Old Nov 26, 2005 | 12:52 PM
comp's Avatar
comp
Originally Posted by Corvette0096
See sig.
nice
Old Nov 26, 2005 | 01:01 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Randy
That will be a challenge without the ability to really 60' the car. It took 480 HP with a mild 406 in my 3400lb nova to run 11.30s - and that car would 60' 1.48-1.52.
It would take really killer heads and some compression to your base 350 into the 11.40 range in a C4. I think you'd need close to 475-500 and to do it, and that might not be enough, again, without a killer 60' set up (slicks, rear shocks, gears, converter, front shocks). And with this stuff, driving across country would be hell on your converter. Add juice and yes.
Old Nov 26, 2005 | 01:11 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Take a look at Vic'89's mods; he currently runs mid 12s with stock heads & cam and has plans to run 11.6s.
Old Nov 26, 2005 | 02:07 PM
rlane5's Avatar
rlane5
The car has been 12.68 @ 108
355 forge piston approx 9.75 comp
LT1 conversion intake
30 lbs SVO injectors
Hot cam
1.5 comp magnum roller rocker
Dart Iron Eagles 180 heads flow 250 int @ 500 lift 190 exh @ 500 lift
2600 Stall converter
3.07 gears
adjustable fuel regulator
TBI chip
nitrous (I want to use unless provoke)
the car needs to be scanned and tuned
It started out this year @ 14.1 when I first brought it, now I have the 11 second itch
Randy
Old Nov 26, 2005 | 02:12 PM
comp's Avatar
comp
didn't find
Old Nov 27, 2005 | 11:36 AM
Vic'89's Avatar
Vic'89
Hopefully I can crack the first bolt next weekend.
Vic
Old Nov 27, 2005 | 12:02 PM
comp's Avatar
comp
all bolt-ons
Old Nov 27, 2005 | 12:22 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Ahhh, the 11 second itch. Sounds like "2 foot fever" for boat owners! I paid and lost thousands with that disease in my boating career. Sounds like you will be doing the same with your 86!
Old Nov 27, 2005 | 01:10 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Hi everyone,
Randy
Two of the better combos that would be sure to get you there with pretty much ease would be
Corvette0096s combo
and
85vet's combo.
The key to achieving the goal is you have to get the entire combo that is the well matched up. That means from intake to converter (assuming auto).
Follow the combos to a T and you will have everything you want.
Both there guys will help you in any way I am sure pick the right components.
To 11 second combo
