Lower Radiator Hose Tips?? Tricks??
Old Nov 26, 2005 | 01:01 PM
EPiC Vette's Avatar
EPiC Vette
Default Lower Radiator Hose Tips?? Tricks??
Replacing hoses today, having problems getting to the lower hose. 1989 coupe, AT (cooler lines), camber brace.
Should I pull the serpentine belt? Any other hints? Got extensions and wobblies, I can get to the clamps... I just can't get a hand around them. I'd cut, but kinda saving that as a last resort.
Discuss!
-Eric
Old Nov 26, 2005 | 01:04 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I replaced that hose on my '88 while I was doing the water pump (WP); so much easier then.
You might want to also remove the serp tensioner for a little more room. I'm not sure if removing the A/C compressor bracket is "necessary" though.
Take a close look and see if you can get a 1/4" drive socket onto the clamp bolts. If you have an angled pry bar it may help in breaking loose the old hose from the fitting on the WP.
Old Nov 26, 2005 | 01:56 PM
EPiC Vette's Avatar
EPiC Vette
I've got the top hose/t-stat assy about done.
I'm chasing a small coolant leak, so I think I'm gonna take CFI-EFI's advice about tracing the problem. If it turns out to be the water pump, I don't wanna have to do all this twice.
Thanks guys!
-Eric
Old Nov 26, 2005 | 02:37 PM
MBDiagMan's Avatar
MBDiagMan
If your budget will stand it, you can get a special tool for this job off of one of the tool trucks or at one of the pro auto tool online vendors such as ToolSource. This tool is a pair of pliers, of sorts, with a cable that goes out to the actuator that you can fit on the clamp. You can get the cable actuator in very tight places with one hand, then squeeze for pressure with the other.
For someone who does lots of work, one of these contraptions is WELL worth the $80 it costs.
Good luck,
Old Nov 26, 2005 | 06:36 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Good luck,
Sears has that same thing (I believe it is a re-badged SK Facom unit) in their automotive section for about $40.
Are your hose clamps the screw type, or the spring type? Those special pliers will only work for the spring type (like on my LT1).
If you have screw type hose clamps... good luck. You might be better off jacking up the car and getting to the lower hose clamp from underneath.
-Ed
Old Nov 27, 2005 | 12:19 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I didn't have a problem, just got the car in the air, loosened the clamps and it came right off.
Old Nov 27, 2005 | 12:33 AM
Aggravated4life's Avatar
Aggravated4life
On L98 engines,remove the tensioner bracket,I think its one 15MM bolt holds it on.With that out of the way,there should be more room to access the clamp on the hose.
Old Nov 27, 2005 | 12:43 AM
EPiC Vette's Avatar
EPiC Vette
Screw-type clamps.
I've been looking for a reason to get a tension pulley breaker tool... looks like thats gonna happen now. It'll be a lot easier with that bracket out of the way.
Thanks, guys!
-Eric
btw, 180 deg t-stat =
To Lower Radiator Hose Tips?? Tricks??
