flashing 5y5 code
Old Nov 26, 2005 | 10:32 PM
POLO96's Avatar
POLO96
Default flashing 5y5 code
my 96 is flashing this 5y5 code . Does anyone know what it means ?
Old Nov 26, 2005 | 11:10 PM
bogus's Avatar
bogus
good question.
The code really means SYS - which means that the code is stored in the CCM. Normally, that means the battery is low.
If you have an aftermarket audio system, it means that the CCM is looking for the factory head unit, and isn't finding it.
There are any number of causes, but those 2 are the most popular.
You need to pull the code, and I don't remember which pins are to be jumped on the later C4s (OBDII).
Old Nov 26, 2005 | 11:38 PM
POLO96's Avatar
POLO96
the car has been sitting a while and needed to be jumped. I have jumped it several times in the past, but never had this code. I put an after market radio a couple years ago. So I should reset the sys. (how ?) and if it happens again probably have the battery checked ?
Thanks for your help !!!
Old Nov 26, 2005 | 11:49 PM
bogus's Avatar
bogus
I will have to dig out the info on resetting. It's all about the pin jumping.
For the most part, disconnecting the battery for about 10 minutes should clear them. If you had to jump it, I would bet on the code being a dead battery code. Also, if the battery is old, either get a charger on it, or replace it. A weak battery will kill an alternator faster than fast.
Old Nov 27, 2005 | 10:54 PM
POLO96's Avatar
POLO96
O.K. I have code H71 and H72. An Alpine radio was put in some time ago, but SYS has just started flashing. What do I do ?
Old Nov 28, 2005 | 11:48 AM
bogus's Avatar
bogus
h71 and h72... those represent dash display issues. I get those codes every so often myself.
reset them and see if they come back.
Old Nov 29, 2005 | 01:27 PM
POLO96's Avatar
POLO96
Yup, they keep coming back ! I notice it does stop flashing when I turn the head lights on. But when I turn them off, it's back.
Old Nov 29, 2005 | 01:34 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I'm betting on the battery.
Old Nov 29, 2005 | 05:04 PM
ittlfly's Avatar
ittlfly
It may very well be the bat. However, I just went through this when I pulled the fuse on my courtsey lights to do some interior cleaning and forgot to replace it. Anyway, The CCM sensed the defaulted circuit and gave me the SYS. Any circuit that the CCM senses and finds a problem will give the code. Check your Helms for those circuits if your bat. checks out OK.
Old Nov 29, 2005 | 05:19 PM
Mr Mojo's Avatar
Mr Mojo
I had a blown fuse and was getting the SYS, but the battery was very weak at that point and actually died a couple weeks later.
Old Nov 29, 2005 | 06:25 PM
steve haverl's Avatar
steve haverl
My 96 LT1 (with aftermarket Sony HU) shows this code when I don't start it for a week or two. After 5-10 minutes of running, SYS goes off.
Old Nov 30, 2005 | 07:33 PM
POLO96's Avatar
POLO96
Well, I sure was hoping it would be the battery. I put in a new Delco and crossed my fingers. I reset the codes, even let it run awhile..
SYS is still there !
Old Nov 30, 2005 | 07:44 PM
bogus's Avatar
bogus
if 1992 is the same as 1996 for CCM codes, H71 and 72 are referring to LCD dimming... 71 = Error, 72 = Open.
Old Nov 30, 2005 | 08:27 PM
POLO96's Avatar
POLO96
The dimmer seems to be working.
Old Nov 30, 2005 | 08:53 PM
bogus's Avatar
bogus
here is my suggestion... invest in the helm manual for your car, www.helminc.com, and follow the troubleshooting guide.
I don't know if the 1992 CCM codes are the same as 1996... they might be, they might not be, I honestly don't know.
Old Nov 30, 2005 | 09:12 PM
stormin310's Avatar
stormin310
replace your battery problem solved same thing happened to me 2 years ago...
Old Nov 30, 2005 | 09:47 PM
POLO96's Avatar
POLO96
Say.....umm....oh .. aren't the guages supposed to light up a little
in the dark before you actually turn the headlamps on ? Maybe that ambient light sensor is bad ? I guess I better get a book !
Thank you everyone for your help
To flashing 5y5 code
Old Dec 1, 2005 | 08:29 AM
POLO96's Avatar
POLO96
Ahhh.....hah,,,SYS stops in bright sunlight and comes back when I cover the ambient light sensor !
Old Dec 1, 2005 | 11:48 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
I bet it has something to do with the aftermarket stereo install. The DIMMER circuit needs to have a resistor put in there to get rid of the flashing SYS, and since you say it comes and goes with the light, sounds like dimmer circuit....
I saved this years ago:
If "SYS" is displayed in the LCD section of the instrument panel cluster after the customer installs a new stereo, he will need to do the following:
1. Buy (2) 1 kilo-ohm 1/2 Watt resistors. [Radio Shack part # 271-023. They sell them as a 2-pack for 29 cents.]
2. Disconnect the negative battery cable.
3. Remove the receiver.
4. Connect one end of both resistors to ignition power. (Yellow wire in the car.)
5. Connect the other end of one resistor to the purple/white wire in the car.
6. Connect the other end of the second resistor to the grey/black wire in the car.
7. Cover all connections and completely cover the resistors.
8. Reconnect the negative battery cable.
Old Dec 2, 2005 | 08:34 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Don't mean to hijack this post
But
Craig, how ya been?
hope to see you at a cruisin soon
Jack
